Accelerator Sensor - Where can I get one? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-26-2009, 07:01 AM Thread Starter
Date registered: Dec 2007
Vehicle: 1998 C43 AMG
Send a message via AIM to MDamg
Question Accelerator Sensor - Where can I get one?
I have a 98 c43 amg. I have been having a throttle issue, and based on the symptoms, I believe it is the Accelerator Sensor.
Q: Is this a DIY project?
Q: Where can I get one?
The symptoms: After hard acceleration, the car goes into some sort of safety mode. The throttle/acceleration is very slow - however, it resets itself when you turn the car off and back on.
Any help is appreciated.
MDamg is offline
post #2 of 4 (permalink) Old 02-26-2009, 07:16 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
I don't ever recall selling one, it's not a common failure.
GeeS is offline
post #3 of 4 (permalink) Old 02-26-2009, 08:20 AM
Kajtek1's Avatar
Quoted: 1068 Post(s)
When I called you GS for Pedal Position Sensor for my 97 E class you didn't have one.
In my car it was placed next to brake booster. Some cars have it build in the pedal.
It is just big potentiometer mounted with couple of small bolts, plug and linkage.
I bought mine at Duval.
Kajtek1 is online now
post #4 of 4 (permalink) Old 02-26-2009, 09:36 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
I went thru it, car shifts fine untill you down shift, then it is limp home mode. Its a probably a MB item, sits up there next to the shock/brake booster, has a bowden cable going to it
012-542-33-17 on my 01E
Peter Guenther is offline
    TPS or Accelerator Position Sensor hhrahman77 W210 E-Class 7 12-14-2014 10:57 AM
    Which O2 sensor? P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2) ClkE C208/A208 CLK-Class 3 05-16-2008 04:44 PM
    accelerator Hemersam W116 S, SE, SEL, SD Class 1 04-30-2008 09:54 AM
    Accelerator mssdoglover W126 S,SE,SEC,SEL,SD,SDL Class 4 10-19-2006 07:22 AM
    accelerator benzito333 W211 E-Class 1 01-16-2004 07:12 AM
