Code 1542 (Pedal Value Sensor or Throttle Position Sensor) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-24-2009, 02:23 PM Thread Starter
Date registered: Dec 2007
Vehicle: 1998 C43 AMG
Send a message via AIM to MDamg
I have a 98 C43 AMG (a C class with the 430 motor). I have a new MAF sensor, just installed 2 weeks ago. Still I have a throttle problem.
I had it scanned, and the code is 1542. This is a Pedal Value Sensor or Throttle Position Sensor, depending who you talk to.
I called around, and I was told this is part of the "Electronic Gas Actuator Slide Valve" - whatever that is. The dealer said it was $1,500 for the part alone.
Can anyone tell me if they have had trouble with this? And what was the remedy?
The problem: Under hard acceleration (ie getting on the highway), the throttle goes into "safety mode". In other words, you can put the pedal all the way to the floor - it takes a few seconds, and then it gradually accelerates. Once I shut it off, and restart, it resets itself. HELP!
MDamg is offline
post #2 of 2 (permalink) Old 02-24-2009, 02:38 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
I had the same symptoms with Pedal Position Sensor in my 97 E300D.
The code was different. The sensor (just bigger potentiometer) retailed at $470 but I got it cheaper from Internet dealers.
Good luck.
Kajtek1 is offline
    throttle position sensor how much????? Ashv8 General Mercedes-Benz 4 10-20-2008 09:50 AM
    Throttle Position Sensor code Baggy W210 E-Class 3 11-16-2007 09:54 AM
    Throttle Potentiometer aka Throttle position sensor 4BRATZ W163 M-Class 1 03-31-2007 03:44 AM
    pedal, position, sensor Chris A General Mercedes-Benz 6 01-10-2007 10:14 AM
    Throttle position sensor meinbenz W124 E,CE,D,TD Class 0 03-01-2005 08:13 PM
