Transmission - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-23-2009, 02:19 PM Thread Starter
Date registered: Feb 2008
Vehicle: 2000 S430
Transmission
I have a 2000 s430. It will not shift in 4th gear sometimes. Took to mercedes shop and they said I need a transmission. Is there a transmission from GM or others that will replace this transmission and can I buy replacement parts. Help me please
Lillie is offline
post #2 of 2 (permalink) Old 02-23-2009, 02:42 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, Lillie, welcome to the forum. Please take a moment to click the user cp link and complete your profile re: vehicle and location as that is often useful information.
You don't mention mileage but if it's never been serviced I would have that done ASAP. And while they are in there have them check/change the pressure regulator spring (on some older models it broke) and replace the adapter/connector on the front right of the transmission (the original design is prone to leaking, fine once you change it). Best to call around and find an indie shop or indie transmission shop that is familiar with the 5-speed automatic, get a few more opinions. If it is indeed shot (which is unusual if that's your only symptom) then you can get a rebuilt unit shipped for about $2,700, with several hundred more to have it installed.
There is also a forum specific to your car, the W220, for specific information that's the best place to post your questions and search for answers.
But no, you can't put another brand transmission in your car. The only way to change the transmission to a different brand is to change the car, too.
Take care and enjoy the ride,
Greg
Check Codes is offline
    Has anyone who changed their transmission fluid had their transmission fail bavenda W163 M-Class 73 01-31-2014 07:32 AM
    Transmission issues (1990 300E, 3.0L, 722.5 transmission) Eric@StarSuzuki W124 E,CE,D,TD Class 5 04-13-2011 07:29 PM
    Automatic Transmission vrs Manual Transmission gentletyphoon General Mercedes-Benz 2 07-27-2008 07:08 AM
    Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK-Class 8 10-07-2002 02:35 PM
    Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK-Class 3 04-26-2002 11:05 AM
