Wheel swap - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-23-2009, 05:44 AM Thread Starter
Miller205's Avatar
Date registered: Jun 2008
Vehicle: 1999 CLK320 Cabriolet
Wheel swap
I recently (this past weekend) put a set of wheels from an newer E320 on my 99 CLK320. I used the same tires I had (205/55/16), but I know the newer rims are 8" instead of the 7" ones that were OEM. I didn't notice any rubbing/scraping, etc, but wondered if anyone knew of issues by putting on a rim that is 1" wider than what came from the factory? And assuming they are ok, could/should I get a wider tire when it comes time to replace them, say a 215/55/116?
Miller205 is offline
post #2 of 3 (permalink) Old 02-23-2009, 11:51 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Miller.
No problem with the wheel in terms of clearance. Unfortunately the width of the new rim is beyond spec for most 205/55 tires (up to 7.5" rim width). I know people play with that stuff; personally I wouldn't, but that's you're choice. I figure the folks that make the tires know what they are talking about, and tires (and the way they seat on the bead) are far too important to take chances with, at least IMHO.
You should be fine with a 215/55-16 (which is the stock W210 tire) as it is just slightly taller than your stock tire and it's fine on the 8" wheel.
However, you said "newer E" and if that means a W211 (2003 and newer) then you also need custom lug bolts. The W211 uses an R14 ball seat, your W208 uses 12M lug bolts. So if you have 211 wheels, you'd need R14x12Mx1.5x26mm custom bolts from radusadirect.com.
If you are using bolts that came with the wheels, then I think you are probably okay, which also means they are W210 wheels. 211 bolts would be too large in diameter for your hubs.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 3 (permalink) Old 02-27-2009, 12:21 PM Thread Starter
Miller205's Avatar
Thanks, Greg - I appreciate the feedback. I'll put a bit wider tire on next time around.
I recvieved lugs from the previous owner, but they were too long. I'm using the lugs from my original wheels, and everything seems ok.
Mike
ML GL Wheel Swap Dudecz190 W163 M-Class 10 01-12-2009 10:30 AM
Wheel Swap trautobro W126 S,SE,SEC,SEL,SD,SDL Class 1 10-18-2008 03:34 PM
Wheel Swap for '81 380SL Jaye hp The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 05-02-2008 05:19 PM
Wheel Swap Dudecz190 W163 M-Class 2 07-03-2007 12:35 AM
Wheel Swap Question tonylinc W124 E,CE,D,TD Class 2 12-08-2005 01:29 AM
