Carsoft 7.4 any good - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-15-2009, 04:53 PM Thread Starter
Date registered: Feb 2009
hello
I was wondering what scanner are we using for 96-newer MB ,.. i found this carsoft 7.4 with the MB port, wondering if anyone is using it and does it work ,
thanks
dporsche74 is offline
post #2 of 3 (permalink) Old 02-15-2009, 06:10 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hey, Porsche, welcome to the forum. Please take a minute to click the user cp link and complete your BW profile re: vehicle and location as that is often useful information.
Carsoft is much more versatile than a simple OBD-II reader, but to leverage that functionality you also need a multiplexer (about $130 on ebay, usually comes with the software) and a laptop with a dedicated serial (COM) port. Then you plug into the 38-pin diag port under the hood.
Search using membername Kobus and the term Carsoft and you'll find lots of information.
If all you want to do is read codes, clear codes and check emission readiness, the little 94169 code reader from Harbor Freight worls great, comes with a CD of code translations, too. You have to be in N.A. for that as it uses the OBD-II port.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 3 (permalink) Old 02-15-2009, 06:40 PM
Date registered: Dec 2002
Vehicle: 2003 SL55 Obsidian Black, 2007 ML500 Silver
Carsoft
Dear dporsche
I would concur with Greg210 (Hi Greg) that Carsoft works well but stress that you need a dedicated serial port on you computer.
It helped me to locate a number of problems on my SL500 (R129) and to delete the relevant error codes
It does not work with a USB to serial adapter. Most modern laptops don't have a serial port. You may need to buy an old notebook like a Dell 610 (cheap on Ebay or local computer traders)
It doesn't pick up the Soft Top mechanism on R129's and there are some equipment groups that it doesn't pick up on a W163. There isn't much to pick up on a W202 that I have tried it on.
Don't bother to buy Carsoft 7.6 as the multiplexer designed for 7.4 does not work with it and you can't buy the correct one as far as I know
Good Luck
Peter Cowie
Sydney
Australia
Cowiepeters is offline
Carsoft 7.4 gary1378 W163 M-Class 28 10-16-2012 11:40 PM
carsoft anyone? phamilton01 W140 S-Class 1 10-27-2008 01:40 PM
What is Carsoft? waterguy R170 SLK-Class 3 04-03-2008 12:44 PM
Carsoft 7.4 - where to get bakselrud R170 SLK-Class 1 09-26-2007 04:58 PM
Carsoft 7.4 nyml320 W163 M-Class 3 08-10-2007 01:53 PM
