Help!My merc 380se is cutting off engine - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-12-2009, 09:27 AM Thread Starter
Date registered: Feb 2009
Post Help!My merc 380se is cutting off engine
I have a 1984 380se that is havin a problem of cutting whenever i stop the car at traffic lights stop signs etc. what are the most likely problems to cause this? I am currently diagnosing the car myself. i have discovered that when the car is "idling" the flap that moves up and down when revving does not close airtyt (which i assume it should") when it is at rest position. Secondly, there is a slight oil leak on the left side of the engine, looks like some of it drips into the spark plugs. engine cranks, fuel pump is working. i avoid the car from cutting by frequently putting my gear in "N" and then revving up before putting it into drive. if however it cuts, it is so difficult to start back into idle again. Someone please help me as i have become imobile due to be a problem that sounds to be minor.
Zhoustar263 is offline
    good deal? Merc 380se for $450 .jrmyrmx General Mercedes-Benz 14 08-26-2008 02:34 PM
    Help my 2.3 16 Please!!!! my engine is cutting out. Shindzzz W201 190-Class 10 08-22-2008 01:30 PM
    Engine Cutting out ska W124 E,CE,D,TD Class 0 09-09-2005 09:47 AM
    Engine Cutting Out Dan G-Class 6 02-24-2002 07:54 AM
    Engine cutting out Dan G-Class 4 01-28-2002 09:18 AM
