Injectors Leaking Compression -2001 Sprinter 313 CDI - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-11-2009, 01:02 PM Thread Starter
Date registered: Feb 2009
Question Injectors Leaking Compression -2001 Sprinter 313 CDI
Hi all, I recently purchased 2001 Sprinter 313 CDI swb. It's started to make a choofing noise which sounds more like an exhaust leak. At first it would come and go but now it's much louder and there all the time & you can see fumes around the rocker cover. I've been told the injector/s are leaking compression causing it to carbon up and now it's seeping from the side of the rocker cover. I could really use some help and guidance as this is a big job and I'm concerned the injectors may be seized in. I also need help diagnosing whether I need to replace the injector/s or whether the seat/seal can be replaced alone, providing they are a replacement part and obviously if that's whats causing the leak and not the injector itself. Thank you in advance.
xmusic is offline
sprinter 313 cdi wierd fault rosin dubh W901-905 Sprinter 8 01-03-2015 05:36 PM
Limp Mode 313 CDI Sprinter garrick@internode.on.net W901-905 Sprinter 9 03-06-2010 03:01 PM
sprinter 2000 2001 313 pecker996 W901-905 Sprinter 2 02-11-2009 05:42 AM
V220 CDI, Bodge of the century for leaking injectors. leesupermoto V-Class 3 08-26-2008 10:56 PM
Looking for a Passengers 15+1 Sprinter 313 CDI near Peru! wayostein For Sale/Wanted/Trade/Giveaway 0 07-28-2007 07:20 AM
