1994 E320 "S" belt, Tentioner - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-08-2009, 04:16 PM Thread Starter
Date registered: Feb 2009
Red face 1994 E320 "S" belt, Tentioner
how can I get instructions & or diagrams that show me where or how to locate tention adjustment to remove & or replace S. belt, on 1994 E320
Pancho Pantera is offline
post #2 of 2 (permalink) Old 02-08-2009, 04:43 PM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 10 Post(s)
Your car could use either the old or new tensioner system, depending on your engine number.
12-072237 is the starting engine number for the new (much better) style. Hope it is because the old style is a real pain. If you have the new style, all you need to do is to use a 15 mm socket to turn the bolt at the center of the tensioner pulley CLOCKWISE to release the tension. You can find your engine number on your car's datacard or use your VIN to check.
If you have the old system, then I suggest you go to the W124 forum to do some search and reading. Be careful with it.
loubapache is offline
    96' E320 doesn't want to Start in "P" but in "N"??? Merc320 W210 E-Class 5 09-26-2008 10:14 PM
    1994 E320 Wagon with stock 15" rims 2005x The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 01-10-2008 11:33 AM
    2001 E320: "Stick" with "MB WorkShop Only" What is this? DanielH General Mercedes-Benz 4 04-21-2007 09:12 PM
    2003 E320 Transmission Question ( "C" or "S") setting jmorgis W211 E-Class 3 11-06-2003 01:05 PM
