ML55 won't rev past 4000 rpm - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-08-2009, 04:11 PM Thread Starter
Date registered: Feb 2009
Angry ML55 won't rev past 4000 rpm
Hi, my first post, my first Benz and my first problem! I have an ML55, 2001 in Australia, fantastic to drive, apart from the amout of fuel it loves to drink, at around $6.50 per gallon it is expensive, but any how!
The Benz drives well but when accelerating it won't rev past 4000 RPM, it just dies, like the engine has failed, if you lift the accelerator pedal it runs fine again. It is still drivable up to around 130 - 140 KPH but I am not able to use the AMG power to accelarate past trucks or cruise at higher speeds. If I want to accelerate slowly or drive slow, I would have bought a Toyota!!
Has any one else heard or had this problem? I live over 100KM from the nearest dealer, and they can't look at the car for nearly two weeks!
Any help or ideas would be appreciated.
Steve from Aus.
deeksy62 is offline
post #2 of 3 (permalink) Old 02-08-2009, 04:46 PM
utiadam's Avatar
Date registered: Mar 2008
Send a message via AIM to utiadam Send a message via MSN to utiadam Send a message via Yahoo to utiadam
does it make any sounds when you try to go past 4,000? Could be a clogged catalytic converter.
utiadam is offline
post #3 of 3 (permalink) Old 03-30-2009, 10:14 PM Thread Starter
Smile Problem Solved
With a new set of 16 spark plugs and a new air flow metre, things are now singing the way they should, probably running the best it has for some time. The 450 km drive home was a joy!!
deeksy62 is offline
4000 rpm rev limit, then it gets crazy!! zeff737 C208/A208 CLK-Class 1 02-03-2009 07:21 AM
400E fuel problems/rev limiter @4000 RPM? zviratko W124 E,CE,D,TD Class 9 08-11-2008 03:02 PM
my 97 E420 won't rev past 5000rpm - why? ProV1x W210 E-Class 0 10-18-2006 06:41 PM
4000 rpm miss??? DONNA U R170 SLK-Class 8 03-15-2005 05:54 PM
Power cutting out at about 4000 RPM Tom V G-Class 5 05-10-2002 03:55 PM
