1999 E320 using excessive oil - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-02-2009, 11:27 AM Thread Starter
Date registered: Feb 2009
My 1999 E320 engine has 115,000 miles and it started using oil excessive oil around 90,000 miles. I am the original owner and always had the vehicle in for proper servicing. When using the vehicle on long trips (750+ miles) the low oil light indicator would light up and checking the dip stick showed that the oil was at the low level. The engine started to use about 1.5 quarts every 1200-1500 miles. Up until recently there was no indication of an oil leak (no oil spots on the garage floor or around the engine.)
On my last trip I topped off the oil and just after 750 miles the oil light indicator went on. At this time, there were oil drops on the garage floor and there was oil leak just under the fan belt assembly. I had it serviced with new seal rings and sealant. But, does this engine use oil at the rate of 1.5 quarts every 1500 miles? That seems excessive.
P Chuck is offline
post #2 of 3 (permalink) Old 02-03-2009, 04:56 PM
Hello I'm Larry a new member. I have a 2000 E320 any mine uses about 2 quarts at 1600 miles. I have no drips or leaks and no tail pipe smoke. Mine has 196,000 miles and I'm concerned.
LarryHof is offline
post #3 of 3 (permalink) Old 02-03-2009, 06:31 PM Thread Starter
Excessive Oil use on 1999 E320
It appears that many owners are reporting similar oil use. No leaks and no oil smoke from the exhaust. Does anyone know whether there was a design flaw with the rings where oil is blowing out of the engine, but not burnt oil where blue smoke would be a tell tale sign? My engine is still getting 29 mpg on the highway and 23 in town. The engine is not running hot, but is consistent, just below the 80 degree C marker.
P Chuck is offline
    Excessive clatter in E320 CDI? daduca W211 E-Class 26 03-11-2012 12:01 PM
    1999 E320 oil change question woodnut W210 E-Class 11 09-23-2004 09:13 PM
    Excessive Oil consumption on ML jloreto99 W163 M-Class 15 07-13-2004 10:23 AM
    1999 E320 Air and Oil Filters...please help DaveE320 W210 E-Class 0 07-03-2004 12:01 AM
    Excessive oil usage Dave W163 M-Class 2 02-07-2002 03:33 PM
