Disconnect ground cable from battery? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 02-02-2009, 06:16 AM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 381 Post(s)
The starting point in many service/repair procedures in the M-B WIS is to disconnect the battery ground cable. Now I can understand this is necessary on certain work, but it is listed, for example, when removing/installing ignition coils.
Can anyone explain what possible electrical damage you can do when doing this simple task?
(This is assuming that the ignition key is out of the car)
keyhole is offline
post #2 of 12 (permalink) Old 02-02-2009, 06:31 AM
Date registered: Oct 2007
Vehicle: 2002 SLK 230 1986 560SL 2008 Honda CRV
IMO, better safe than sorry. Any kind of a spike will raise hell with these cars.
livefreeordie is offline
post #3 of 12 (permalink) Old 02-02-2009, 06:39 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
I assume in case of ignition coils it is a safety/liability issue more than technical. The ignition system should tolerate pretty strong spikes anyway. Elsewhere it may be critical.
Diesel Benz is offline
post #4 of 12 (permalink) Old 02-02-2009, 09:14 AM
Kajtek1's Avatar
Quoted: 1197 Post(s)
Far going precaution, but so are ABS, airbags. ESP and tons of other gadgets we are using every day.
On my Ford pickup I welded frame for the dump bed. That was several hours of welding with high voltage spikes on the body. I never disconnected the dual batteries and nothing got fried. Ford has lot less electronics than MB, but still.
Kajtek1 is online now
post #5 of 12 (permalink) Old 02-02-2009, 09:37 AM
A couple of years ago i installed an anti-zap device on the battery which protects the electronics from spikes, it works great. Do a search for more info. Lots of post's about them.
post #6 of 12 (permalink) Old 02-02-2009, 12:36 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Why is this even an issue? It takes 30 seconds to disconnect the battery.
mr.xpowerseller is offline
post #7 of 12 (permalink) Old 02-02-2009, 02:49 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
You're going to need a radio code following disconnecting the battery.
May have to "reset" windows, sunroof, etc.
Details in owners manual.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #8 of 12 (permalink) Old 02-04-2009, 06:08 AM Thread Starter
keyhole's Avatar
Quoted: 381 Post(s)
What I am asking is - without the ignition key in place, and turned on, what exactly is live at +12v that could be shorted to ground? (Obviously excluding the clock, etc) Surely everything else is isolated via relays, control units, etc?
For the past 20 years I have changed light bulbs, and other electrical bits with no problems without isolating my battery. But not on M-B. so maybe just lucky.
keyhole is offline
post #9 of 12 (permalink) Old 02-04-2009, 08:19 AM
Quoted: 35 Post(s)
I did not check but the ignition system probably is out of power but most control units do have constant power on, many don't have switched power input at all. Those are just switched to low power mode via CAN signalling.
post #10 of 12 (permalink) Old 02-04-2009, 10:29 AM
Quoted: 2 Post(s)
I frankly don't worry much about battery disconnecting.
The key is, of course, to be careful.
For DIY, it's your car, so you pay. Professionals need to be careful, as they shouldn't be able to charge for their mistakes.
I'd certainly never worry about this working on spark plugs, coils, etc. If these things retained charges, the engine would still be running. Certainly changed plugs/wires and CPS on an M112 with no worries.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    battery disconnect revolt1112 W163 M-Class 11 05-02-2012 11:39 PM
    how does one disconnect the battery? S320_on_18s W140 S-Class 13 05-21-2009 02:03 AM
    107 Battery ground cable corrosion nortonfan Vintage Mercedes-Benz 0 08-03-2006 11:04 AM
    hood cable disconnect kreuser914 W201 190-Class 3 02-15-2005 07:36 AM
    Battery Disconnect harb W210 E-Class 11 12-14-2004 01:36 AM
