97 Mercedes E420 Running Hot - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-31-2009, 06:16 PM Thread Starter
Date registered: Jan 2009
I Have a 97 E420 its running hot,the temp gauge is between 80 and next mark when it hit the next mark the fan came on to cool the engine off i guess but it made a very loud noise, I had thermastat change and it is still at the 80 and above knotch. What else could it be?
agreen is offline
post #2 of 3 (permalink) Old 01-31-2009, 07:43 PM
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
Quoted: 12 Post(s)
See this thread in the W210 forum.
http://www.benzworld.org/forums/w210...nning-hot.html
A few other things to check are the auxiliary fan switch and viscous fan clutch.
The auxiliary fan should come on between the partial coupling and full coupling of the viscous fan clutch.
These engines do like to run a bit warmer and there should be quite some info on this if you search around.
loubapache is offline
post #3 of 3 (permalink) Old 01-31-2009, 07:59 PM
Quoted: 12 Post(s)
About the noise.
Was it a fan noise or water gushing noise? You may take a look at the coolant recovery tank to see if the coolant is moving (boiling). That would indicate a bad coolant recovery tank cap. It costs about $5.
Car running finally is it running hot or O.K. cheapold280ce W123 E,CE,D,CD,TD,TE Class 15 04-23-2008 06:42 PM
My 2.6 running hot rjb190e W201 190-Class 27 05-30-2007 09:42 PM
running a little hot mikroehl W202 C-Class 0 02-07-2006 03:41 PM
running hot jc10 G-Class 4 10-19-2004 07:26 AM
Running Hot !? modojojo W163 M-Class 3 06-06-2003 08:21 PM
