Wiper Not Working on 1990 300D - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-31-2009, 02:47 PM Thread Starter
Date registered: Jan 2009
I have a 1990 300D (diesel). It has 1 wiper.
All of a sudden the wiper does not work. I have no idea why.
I am not sure if it is just a fuse issue (if so, where is the fuse box and which fuse do I look at).
Any ideas/suggestions would be greatly appreciated
roseytoys is offline
post #2 of 2 (permalink) Old 02-04-2009, 01:23 PM
Date registered: Dec 2007
Vehicle: 250 TD W124 RHD 1989, E300 TD 1999
I had a problem with the wiper on my 250TD 1989 - I'm still not exactly sure how I fixed it but here are a few pointers :-
1) fuse is a likely suspect - the box is in the engine bay on the right hand side near the back bulkhead (ie on the opposite side to the battery). There should be a card in the lid which shows which is which. The originals are aluminum torpedo type but the holders are copper which causes problems. You can buy replacement copper fuses which are supposed to be a good idea.
2) if the gulley near the fuse box is blocked, rainwater will cascade over it (guess how I know :-)
3) There is a black plug-in repeater in the box behind the fuses - I believe it controls the flasher for the indicator and the repeat on the wiper
4 ) The indicator stalk on the steering wheel is quite a likely culprit - they can burn out internal connectors. Be careful if you decide to take it apart as it has some little springs inside that pop out (guess again !) If you do need to replace the stalk then the steering wheel has to come off - hex bit long arm bar - 5' extension bar and a strong friend required in my case.
Good luck
nickdub is offline
    odometer not working on 1990 sl500 jwh1951 R129 SL-Class 3 07-18-2016 12:05 PM
    1990 190e wiper problems Scot C. W201 190-Class 3 03-18-2008 09:54 AM
    1990 300SEL wiper cover removal for lubrication? rcltrh W126 S,SE,SEC,SEL,SD,SDL Class 1 05-27-2006 08:53 AM
    driver's wiper is not working aggarao G-Class 4 02-23-2006 03:43 AM
    1990 Infrared lock system not working kevfra R129 SL-Class 5 07-28-2004 08:20 AM
