leaking fuel tank - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-31-2009, 07:08 AM Thread Starter
Date registered: Jan 2009
leaking fuel tank
My name is Ray and I live in Florida. In November, I bought a 2005 E320. The other day the "check engine" notice came on, and they found a leak in the top of my fuel tank, under the rear seat, that was creating fumes. There were no spots under the car in the garage nor odors in the car. He tells me it is plastic---hard to understand how it could get punctured----but the estimate to replace it was over $2400. And it's out of warrante. Could not a plastic tank, with a leak on top, be patched???
rayjay1127 is offline
post #2 of 2 (permalink) Old 01-31-2009, 07:17 AM
Bill A's Avatar
Quoted: 27 Post(s)
I have never seen one repaired but I have changed maybe 6 tanks myself. The leakage is usually in the vapor control area for emissions control and is many times hard to diagnose. There is a charcoal canister shut off valve mounted next to the filler assy. that often is the culprit. If I were you I would contact Mercedes Benz ask for assistance as the repair is quite costly and the failure is nothing you may have caused/ They will usually step up for a part if not the whole ticket. Having a strong service history is to your advantage in cases like this one. If the car has oner 100000 miles forget it though. Bill
Bill A is offline
    Fuel tank takes quarter tank full of gas less than what it used to take! Labik34 W140 S-Class 13 07-19-2008 04:15 PM
    Me gas tank is leaking into the trunk >_< 240DieselPower W123 E,CE,D,CD,TD,TE Class 3 07-16-2007 09:08 PM
    leaking fuel tank bluejay6250 R129 SL-Class 4 09-03-2006 07:48 AM
    Was something loose? I filled my gas tank, and my fuel meter never reset to the full tank reading.. AC_ML W163 M-Class 5 08-20-2004 07:12 AM
    Leaking Gas Tank ... schneideris W163 M-Class 10 09-21-2003 08:15 AM
