Blower motor trouble - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-28-2009, 08:38 PM Thread Starter
Date registered: Jan 2009
Vehicle: 1990 300te
Post Blower motor trouble
I just picked up a 1990 300 te and the blower motor doesn't come on even after letting the car get completly up to operating temp. Any ideas on where to look first? It gets rather cold in northern Michigan
yamifrk is offline
post #2 of 5 (permalink) Old 01-30-2009, 11:39 AM
tuttebenne's Avatar
Date registered: Jul 2005
Quoted: 208 Post(s)
Blower motor failures are quite common in the 124. The likely cause is the regulator which is mounted under the motor, which is under the wiper assembly. But first you want to check the easy stuff:
- check the fuse that is for the heater; the fuse is found in the fusebox,
- check the blade fuse which is located in the engine compartment. It is concealed within a black plastic box that is maybe 3/4 of an inch wide by two inches long. The box is mounted over the driver's front wheel arch and has a wire going into it from the left and from the right sides. This fuse should be taken out and inspected because they can be cracked and not visible if you haven't dealt with them before.
There are multiple threads here that will walk you through the process if these two simple checks don't yield the cause of your blower motor problem.
'89 300E
'90 300CE
'93 400E
'93 500E
'00 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #3 of 5 (permalink) Old 10-19-2011, 03:06 PM
Date registered: Aug 2011
multiple threads
Does anyone know where I can find the multiple threads on replacing my blower motor on my 1988 300 TE ? Any help would be greatly appreciated. Thank You Mark
drumhead87m is offline
post #4 of 5 (permalink) Old 02-13-2012, 06:44 AM
Thanks YOU tuttebenne for the reply ......drumhead87m
post #5 of 5 (permalink) Old 02-13-2012, 08:59 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
I would peruse the W124 section.
GeeS is offline
    1998 W210 E300DT Bad Blower Regulator or Blower Motor?? How to tell DieselNuts W210 E-Class 12 08-16-2012 09:32 AM
    blower motor jmoney6 W124 E,CE,D,TD Class 6 03-04-2008 12:21 PM
    Blower Motor Help Please N1ML W163 M-Class 4 10-12-2005 07:42 PM
    Blower Motor Help Please N1ML W163 M-Class 0 10-11-2005 04:21 PM
    Wiper Motor or Blower Motor / Resistor Pack Failure?? jangr320 W163 M-Class 3 11-13-2004 11:20 AM
