check lamp message - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-28-2009, 02:28 PM Thread Starter
Date registered: Jan 2009
Vehicle: 2002 mercedes benz E320 4 matic wagon
check lamp message
hi, all
I'm new here. I come here because I have a problem with my car E320 4matic wagon. the check lamp light on. and I changed the parking light on the right side. the light is working good. but the check lamp light keeps on every time I start drviing. I cannot erase the message.
is someone can help me?
thanks a lot.
Charlie
charliefoo101 is offline
post #2 of 7 (permalink) Old 01-31-2009, 07:52 AM
hsahai's Avatar
Date registered: Aug 2008
Vehicle: MB 420SEL 1986-Bought in 2010, MERCURY VELLAGER-1995, NISSAN MAXIMA 1996, Buick Lesabre 1995
Check lights at night. Make sure head lights high and low beam. Also check licanese Plate light bulbs. I hope this should do the trick.
Sahai
hsahai is offline
post #3 of 7 (permalink) Old 01-31-2009, 08:36 AM
Smalls's Avatar
Date registered: Jul 2008
Vehicle: W211 '07' E320 Bluetec
Also you can clear that msg so you can see your outside temp mileage etc by meshing on the R button(right beside the msg console buttom button) to reset any error msgs. This is just a temp solution but do check on the light as hsahai as mentioned above, good luck.
Smalls is offline
post #4 of 7 (permalink) Old 01-31-2009, 08:04 PM Thread Starter
thanks a lot. I've checked all lights. they are working. today I drove the car, the message came out again after a while, sometimes couple of mins or one two house.
can I get a code reader to erase this message? thanks
post #5 of 7 (permalink) Old 02-01-2009, 12:05 PM
hsahai's Avatar
One thing more before you erase the message. this heppened to me one time. check lamp inidcator was coming on and off intermittently. What I notice that one of the tail light bulb was loose in the bulb socket. if you move the bulb little bit it will flicker. So I change the bulb and then problem was solved.
Sahai
hsahai is offline
post #6 of 7 (permalink) Old 02-02-2009, 07:02 PM Thread Starter
today I found that the message came out only when I press brake. but brake light bulbs are good. I remember that they replaced the front brake pads months ago. there is a sensor there, they pull it out and insert it in the new pad. I'm not sure about what the sensor for, I gues it's for thickness of pad. is there something there to traggle the message on?
please help.
post #7 of 7 (permalink) Old 02-04-2009, 12:22 PM Thread Starter
if brake switch has problem, that will get message on? help!
E430 lamp defective message - vanity mirror lamp out mgia0007 W210 E-Class 7 01-04-2009 01:11 PM
Lamp Message?? ETP W210 E-Class 11 04-10-2008 06:24 AM
defective lamp(s) message hyacinth W210 E-Class 1 08-27-2007 06:25 AM
Lamp Error Message Nor-Cal-CLK C208/A208 CLK-Class 6 08-09-2007 10:41 PM
Message ...Lamp is Defective tallsweet W210 E-Class 3 09-21-2006 07:29 PM
