92 E300 Fixer (almost) - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-27-2009, 02:27 PM Thread Starter
Date registered: Jan 2009
Question 92 E300 Fixer (almost)
I inherited a 92 E 300 4matic, my wife drove it for 6 months and then had a wreck which took out quite a bit of the front end. I let it sit for about four years before I finally took to getting it back on the road. I have replaced the distributer cap and rotors, spark plugs and cables, fuel filter, air filter, radiator, liquids, and so on. I also cleaned the electrical connections with anti-oxidizing contact cleaner. The car is mostly back to running but it sputters on acceleration and often dies when I come to a stop.
Came across the Forum and it looked like it has many intelligent contributors. I learned how to run the DTC tests from the info I have read; but while it says to use pin 1 for ground Black), pin 14 for codes (yellow), and 16 for power (Red)(no female in plug so I just used positive terminal) I get 1 blip which signifies no errors.
I did, however, use the other terminals for codes and got:
Pin 3 I got 4 and 7
Pin 6 I got 3 and 8
I will keep looking for specifics on what the codes mean, but if anyone could help it would be appreciated.
cotrofeld is offline
    fixer upper aelmore W202 C-Class 9 06-22-2007 12:13 PM
    DIY Budget Fixer crash9 Off-Topic 0 10-12-2005 06:47 AM
    NICE FIXER UPPER!!! Smokiesman W124 E,CE,D,TD Class 9 05-22-2005 07:52 PM
    Local Wheel Fixer osdesierto W203 C-Class 2 12-14-2004 06:06 AM
    TRANSMISSION FIXER!!!!! zoran W123 E,CE,D,CD,TD,TE Class 3 10-09-2003 04:45 PM
