Check engine light and Service E - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-26-2009, 09:21 AM Thread Starter
Date registered: Feb 2008
What indicators effect the check engine light ours came on yesterday then went off after I removed and reset the gas tank cap. I couldn't find anything wrong but after a while the light went off. Also what is a service E I can't find anything on it in the manual and the dealer won't give me a good answer they want to see the car and the check book.
priesendorf is offline
post #2 of 5 (permalink) Old 01-26-2009, 09:36 AM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
The check engine lamp is tied into most anything that can effect emission release into the atmosphere. There is a sensor in the fuel tank chain that senses pressure build up and release so integrity can be monitored so alas a loose gas cap will cause a lamp to light on the dash. If it se's a return to vapor tightness it will extinguish. A e service is a safety inspection with oil change. Depending on your model and year there are several systems used to report on the cars needs. If you have a late model with service plus the service needs are stored in a computer on board and must be accessed either from the dash assy. of via a computer diagnostic system at the dealer hence he needs to have it first hand to querry the on system. Hope this helps.
Bill
Bill A is offline
post #3 of 5 (permalink) Old 01-26-2009, 12:09 PM Thread Starter
Thanks and is there anyway to know what this service should cost?
post #4 of 5 (permalink) Old 01-26-2009, 12:12 PM Thread Starter
Sorry Bill our E350 is a 2007 and has around 50K
post #5 of 5 (permalink) Old 01-26-2009, 12:18 PM
Bill A's Avatar
Quoted: 27 Post(s)
I don't have a specific list per say. At 50000 miles it probably needs a oil and filter service, a brake flush, cabin air filters, tire rotation and usually brakes of one type or another. Are you near a dealership?
Bill
Bill A is offline
2002 c 230 check engine light and srs light upstaterider2003 General Mercedes-Benz 4 08-04-2008 07:35 AM
1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
would blown dashboard light make check engine light go on? ae98 R170 SLK-Class 3 10-07-2006 12:36 AM
check engine light & flashing fuel guage light pd99sl500 R129 SL-Class 7 02-27-2005 04:31 PM
