'94 C280 Window washer and High beam switch won't work - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-25-2009, 04:57 PM Thread Starter
Date registered: Jan 2009
I have had this 94 C280 for over a year and haven't notice the high beams or the window fluid spray not to work until just last week it stoped all of a sudden and along with the high beams not able to come on. Switching to high beams just turns the head lights completely off when activated. I'm not sure why this would happen but the switch may be the problem concidering they both are activated from the same switch lever on the right side steering column. Anyone with a resolution to the problem other than to purchase another switch. Or would that be the only thing that could be wrong with my high beams and washers.
jayt415 is offline
post #2 of 2 (permalink) Old 01-26-2009, 06:41 AM
Bill A's Avatar
Quoted: 27 Post(s)
Well if you had a diagram for the wiring and an understanding of auto electrical function it is a easy thing to diagnose. It would be a bitter pill to replace the switch and discover a power supply issue in the fuse box. Just a thought.
Bill
Bill A is offline
washer fluid switch? bigmellon Unimog 10 01-02-2008 01:44 AM
windscreen washer does not work. daveyg W220 S-Class 5 05-19-2007 05:24 PM
300te...rear washer does not work...why? AlanS W124 E,CE,D,TD Class 2 03-29-2007 11:41 AM
Washer/Wiper fluid pump does not work 400SEL W140 S-Class 1 12-22-2003 04:50 AM
Rear washer doesn't work, any ideas? bavenda W163 M-Class 2 11-18-2003 10:51 AM
