1995 S 500 coolant level low - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-22-2009, 06:54 PM Thread Starter
Date registered: Jan 2009
My coolant light stays on so how long can I drive the car before putting coolant in?
dock7259 is offline
post #2 of 5 (permalink) Old 01-22-2009, 07:19 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
The light is named an idiot light for a reason. If the light needs to come on, then you have already gone too far. Adding coolant is cheap, takes 1 minute and does not take an advanced technical degree to do so.
mr.xpowerseller is offline
post #3 of 5 (permalink) Old 01-22-2009, 08:50 PM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
If this is less than 1" needed you can add just water (distillate is recommended)
For bigger additions buy MB coolant. If your coolant is old -now is a good time to change it.
Kajtek1 is online now
post #4 of 5 (permalink) Old 01-23-2009, 12:50 PM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
You can go for a long time, but I don't think that is a Wise Choice.
Antifreeze/Coolant not only keeps the Engine and Tranny Cool but it also
prevents Engine Freeze.
Antifreeze is like Engine Oil. Add it because it's so darn cheap and when
your Engine/Tranny breaks down, you will kick yourself in the head.
It's what? $7/Gallon for Xerex G-05?
Check your Owners Manual.
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #5 of 5 (permalink) Old 01-23-2009, 03:18 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Have you checked the coolant level by looking under the hood? There is a lever on the left-side kick panel in the driver's side knee well. Pull that and the hood will unlatch. Then raise the hood slightly by lifting the bottom of the grill. A small plastic 't' will protrude from the top of the grill opening. Pull that and lift the hood. Look to your left at the front of the engine. There should be a large white plastic container. It holds the coolant overflow. There is a raised horizontal line toward the top that is "full hot." There is another line lower down that is "full cold." Depending on whether the engine is warm or not, there should be liquid above the bottom line and at or just below the top line. If the liquid is below the "full cold" line when the engine is cold, you should add MB approved coolant to that line or slightly above it.
The 'check coolant' light should go off after this.
Hope this helps.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
    Engine Coolant Level Low intermittent light Dan R170 SLK-Class 10 10-16-2008 01:16 AM
    FS - Low Mileage 1995 S-500 Coupe (E-Bay) tbyrne For Sale/Wanted/Trade/Giveaway 1 10-24-2005 09:28 AM
    Low Coolant Level Warning Light, but fluid is full ksing44 W124 E,CE,D,TD Class 1 09-05-2005 02:55 PM
    Low coolant level slk05amg R171 SLK-Class 3 06-05-2005 02:43 PM
    Coolant Level anant369 R170 SLK-Class 2 01-14-2003 01:23 PM
