PROBLEMS WITH ANTITHEFT 89 124 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-22-2009, 01:07 PM Thread Starter
Date registered: Jan 2009
Vehicle: 93 500 SEL,89 300E, 91 320 SEL
GENTLEMEN, WAS LUBING THE WINDOW REGULATOR ON THE DRIVERS SIDE WHEN I0 BROKE OFF A CONNECTOR ON THE ACTUATOR. IT GOT WORSE AS I TRIED TO FIX THE CONNECTOR. THE PLUGS CRUMBLE LEAVING WIRES EXPOSED WITH NO WAY TO RECONNECT WITH OUT A WIRING DIAGRAM. I CANNOT FIND A COMPLETE DIAGRAM THAT SHOWS THE WIRES AT THE DOOR HANDLE SWITCH AND THE ACTUATOR. I WENT TO WRECKING YARD AND GOT NEW CONNECTORS AND INSTALLED THEM JUST TO HAVE THE ONE THAT GOES INTO THE DOOR. THERE IS ONE WHITE PLASTIC PLUG WITH ONE WHITE WIRE AT THE DRIVERS DOOR. THIS PLUGS INTO A 3 WIRE CONNECTOR WHICH HAS A BROWN, YELLOW GREEN AND GREEN BLUE. AT THE DOOR LOCK ACTUATOR (WHICH IS CONNECTED TO THE DOOR HANDLE BY A ROD TO THE ACTUATOR)
THE ACTUATOR HAS A RED/WHITE, A BROWN AND A BLUE. THE CONFUSION IS AT THE DOOR AND WHERE THE 3 WIRES PLUG INTO WHICH PIN OF THE WHITE CONNECTOR WITH THE SINGLE WIRE. THE FLAT PART OF THE 3 WIRE PLUG WHICH WOULD ALIGN IT WITH IT'S CONNECTOR, BROKE OFF. CAN ANYONE TELL ME THE PROPER CONNECTION FOR THE WIRES TO THE PINS USING THE FLAT PART OF THE CONNECTORS AS A REFERENCE POINT? THANKS IN ADVANCE, PAUL
HEESPAUL is offline
Antitheft nisstitan W203 C-Class 0 04-18-2008 03:21 PM
124 Climate control problems? Diverter pods shot? pkmaven W124 E,CE,D,TD Class 3 06-28-2006 09:59 AM
ANTITHEFT Devices deutsche280 W202 C36 AMG, C43 AMG 9 06-27-2006 04:49 PM
Should I install LoJack..- antitheft device..? M-Brabus W220 S-Class 4 02-13-2005 11:07 PM
antitheft alarm juan74 W123 E,CE,D,CD,TD,TE Class 1 06-20-2004 01:29 PM
