Engine Oil Query - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-22-2009, 12:50 PM Thread Starter
Date registered: Jan 2009
Thumbs up Engine Oil Query
Hi. Hello there, I'm a new member who uses a van for recreation only, the last vehicle was a C200 Sports Estate but found it was lacking a seriuos amount of space in the back so Ive just purchased a 2006 WDF639 Vito 111cdi 2.2 deisel and would like to give it an oil change, ( I dont trust these lengthy service intervals) I have been told that the vehicle has a particulate fiter and requires a special oil other than the normal semi synthetic I have used in other vans (and car) I have owned and serviced every 3 months the mileage I do is very low approx 8000 miles per year, Could anyone advise on what type of engne oil is reccommended for this type of engine.
Cheers. Kevex:
kevex@btinternet.com is offline
post #2 of 3 (permalink) Old 01-22-2009, 01:03 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Mercedes publishes a list of oils it has approved for its various vehicles.
You're clearly not from USA so best advice I have is to ask a Mercedes dealer or post at a forum in your country.
It is very true that vehicles with diesel particulate filter require matching motor oil, and the specification we use is Mercedes 229.51 (not interchangeable with 229.5)
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 01-22-2009, 02:08 PM Thread Starter
Cheers for that very quick reply, I'm trying to steer away from the dealerships however If i have to go there then so be it, I'll make enquiries. Kind Regards.
Kevex....Great Britain.
    oil consumption: volume query joyfulheart R171 SLK-Class 15 01-03-2007 10:44 AM
    How much engine oil to bring oil level from min to max? allerton W126 S,SE,SEC,SEL,SD,SDL Class 15 07-26-2006 05:50 AM
    Newbie Query: W124 Offset Query Rim Width happy_jon The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 07-13-2003 04:16 AM
    500 SEC ENGINE QUERY sssammm W126 S,SE,SEC,SEL,SD,SDL Class 3 03-16-2003 01:19 PM
    My 96 S320 to have a cracked engine block gasket, which cause a oil leak .All oil changes (more)... Guest (MBNZ) W140 S-Class 2 04-19-2002 01:34 PM
