92 500sl r129 - front is sitting on the ground - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-19-2009, 11:16 AM Thread Starter
Date registered: Jun 2006
I have a 92 500sl R129, the car was sitting for about 2 years and I recently replaced a lot of things before starting her up again that I knew needed replacing. I also replaced the front suspension "spheres" that connect to the hydraulic auto leveling suspension, I think it's called ASR or something like that?
The car has always had issues with the front sitting too low, so after all the work i start her up and everything is working fine except for the suspension. The front is sitting as low as it possibly can, I let the car run for a good 1 hour thinking it might bleed the air out, i tried to bleed it at the pump and at the front spheres. Still no luck.
A few things to note:
* pump is working, bleeding at the pump results in lots of fluid coming out and onto the ground. Doesnt shoot out with high pressure though, more like "burps".
* When attempting to bleed at the spheres, i get almost no fluid, just a tiny bit comes out and thats it, then no more than drip drip drip
* The return line to the reservoir looks like nothing is coming out of it. I might be wrong, but isnt the return line supposed to constantly have something coming out of it back into the reservoir?
Any suggestions? Any links or writeups that might help?
baktasht is offline
post #2 of 2 (permalink) Old 01-20-2009, 12:59 PM Thread Starter
I've checked the actuators. The rear one looks fine. The front one looks fine, but the arm is not connected to anything. What position should it be in?
Also, should the pump be spraying out at high pressure when i disconnect the hose at the pump, or just dribbling out? Mine just dribbles.
baktasht is offline
    500SL (R129) --> SL 55 (R129) 500 + hp EST-R129 R129 SL-Class 43 03-25-2011 01:41 AM
    R129 - 91' - 500Sl - 500 HP Q? StuartKnight R129 SL-Class 8 12-01-2007 10:05 AM
    W124/R129 500E/500SL front calipers & rotors M104-AMG For Sale/Wanted/Trade/Giveaway 0 08-12-2007 07:45 PM
    front windows not sitting flush 78-450 slc R/C107 SL/SLC Class 9 05-05-2007 04:03 AM
    R129 500SL Parts Wanted gorfllub For Sale/Wanted/Trade/Giveaway 0 02-13-2007 02:31 PM
