1982 240D Water leak - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-17-2009, 12:26 PM Thread Starter
Vehicle: 1982 240D
I have an interior leak that causes water to come into the passenger side of my 1982 240D. After unplugging all drain holes and cleaning out leaves and needles from the hood and trunk it still leaks. After taking the carpets out (again, this is passenger side only) I noticed that trickles of water come in through cracks that have appeared where the front passenger would put his/her feet. I had thought that was metal but it seems to be some kind of super hard plastic-like material. Anyway there are cracks in it and water is coming through those cracks. I'm assuming that the water would normally flow behind that barrier and out through the drain holes but that some is trickling through.
Has anyone else had this experience and is the solution simply to apply a sealer along all the cracks. It doesn't matter how ugly it looks because it will be covered up by the carpet.
Any thoughts would be greatly appreciated.
Peter
psnewman is offline
post #2 of 2 (permalink) Old 01-17-2009, 12:33 PM
Date registered: Feb 2008
Vehicle: 1987 420SEL
I had the exact same issue with my 300D, and it is an inherent problem with most LHD W123's.
The super-hard plastic filler you describe is just a type of sealant used by MB (and other manufacturers) to fill in seams and valleys during the manufacturing process of the body shell. If you remove the plastic surround on the passenger side of the cowl, the little black (on lesser models, chrome on 300's etc) grate, you will find the drainage areas for water that comes into the grates. To remove, simply push the centre section of the square plastic rivets in, and then pull them out. Be sure to retrieve all of them, or purchase a new set from MB. You will probably have to remove the windshield wiper arm for that side too.
If these areas are leaking, dry them out thoroughly, preferably over a few days (no rain, heat gun works but careful not to burn anything), and seal them with whatever quality sealant you see fit. Home latex caulking is no good; you'll find a satisfactory product at your local auto parts store.
There IS a way of re-routing the water to flow away from the passenger side vent (inside), by attaching a length of rubber hose to route the water towards the left side of the inner cowl, but I haven't seen the inside of the cowl for a W123 in a long time, so I can't provide specifics. There is a way to do it, however.
(On Edit)- I'm pretty sure the rivets only go in "one way", as they're not entirely square, so mind that.
Benz Prodigy is offline
1982 MB 240D 240D82 For Sale/Wanted/Trade/Giveaway 2 08-27-2007 02:12 PM
1982 240d FRED 524 W123 E,CE,D,CD,TD,TE Class 10 03-02-2007 08:12 PM
Wiring loom - insulation falling off, water leak, oil leak sjc123456789 W124 E,CE,D,TD Class 3 02-10-2006 10:24 AM
1982 240D TCB W123 E,CE,D,CD,TD,TE Class 0 05-28-2005 06:33 PM
1982 240D TCB W123 E,CE,D,CD,TD,TE Class 8 12-16-2004 07:32 PM
