Need Mechanics opinion on issue - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-16-2009, 09:06 PM Thread Starter
Date registered: Jan 2009
Fuel pump or not???
00' ML320
I am a old school jeep guy and have knowledge on old school motor issues but I am helping my nephew on his MB.
Motor running rough, would die on acceleration, idled ok, no power. Not drivable.
Bought a code reader and am getting mixed results occasionally no codes and when I get codes it is P0300, P0301 and last time it was P0300, P0301 and P0303. I understand what the codes say.
Thought coil pack but ruled that out right now. Thought fuel filter removed it, tested pump and saw good flow, and just replaced it.
Car will crank, run a few minutes die. When it died I removed the fuel line going into fuel rail, cranked motor no fuel. Reconnected.
Waited a while until it cranked and ran. Turned it off, removed line going to fuel rail, tried to crank and fuel poured out. Reconneted. Cranked engine, ran for a few minutes and it cut died.
Removed fuel line at rail turned over would no flow.
Repeated the above several times. Basically, if I checked at the fuel line t rail times it was running I would get good flow. If I checked immeadiatley after it died I would get no flow.
As an old school guy, I determine it HAS to be the fuel pump. Is there anything I might be missing that still calls that into question??
EDIT: I removed the fuel line going to the input on the fuel filter. Turn motor over and get no fuel. Fuel pump? The only question I would have is if there is some shut off to the fuel pump from the computer or other sensor? On a '72 CJ5 there is not and the answer is obviously fuel pump..MB ??
sorry for the long post..
CJ5 is offline
post #2 of 3 (permalink) Old 03-31-2009, 05:02 AM
Date registered: Mar 2009
Vehicle: 1979 450SEL 6.9, 1991 300E, 1999 ML320, 1999 SLk230 KOMP, 2003 S430 4Matic (Certified MB Tech)
they had a prob with the harness check behind the L/R wheel you should see a connector seperate it and make sure the connections are good
ernie300w is offline
post #3 of 3 (permalink) Old 03-31-2009, 05:34 AM
eric242340's Avatar
Quoted: 283 Post(s)
Crankshaft position sensor With no signal from this there is no power to the pump. Sometimes the sensor works and sometimes it fails but on the ML model it will not (always) throw a fault code.
eric242340 is online now
    Opinion on possible alignment issue NationsMostWanted W204 C-Class 8 06-11-2008 06:50 AM
    Might buy this 95 E320, an issue, need YOUR opinion Benzadmirer W124 E,CE,D,TD Class 20 03-07-2008 06:12 PM
    Mechanics? hrhvic Vintage Mercedes-Benz 0 04-12-2007 04:37 PM
    Radio Harness issue, Tuner issue DamianC R170 SLK-Class 1 08-28-2006 06:46 PM
    Brake-light issue leading to BAS/ESP issue??? Isoplus R170 SLK-Class 7 06-17-2006 12:57 PM
