ML320 FUEL PUMP HELP - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 01-11-2009, 11:06 AM Thread Starter
Date registered: Jan 2009
ML320 FUEL FILTER HELP
you might have seen my post on other forums but i still get no answer, I just got a 01 ML320, i want to change the fuel filter, the numbers on the filter NOW is 1634770501 , so im thinking it must have been upgraded from the discontinued 1634770201, now my question is all what im finding at part stores and online is fuel filter 1634770701 did they discontinue the 0501 one again or did they just replace the part #'s ?? and 0701 will fit?
any help would be great..
ml320red is offline
post #2 of 19 (permalink) Old 01-11-2009, 12:21 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
The A163 477 05 01 filter has been changed to A163 477 07 01. You should not need parts A163 470 28 64 / A163 470 29 64 now if you previously had A163 477 07 01 filter.
Diesel Benz is offline
post #3 of 19 (permalink) Old 01-11-2009, 12:43 PM Thread Starter
so what your saying is that A 163 477 05 01 is the same filter as A 163 477 02 01??
im not sure what your saying here, every forum says the filter A1634770201 was discontinued ,but what i have on my ML320 is A1634770501 there two diff. numbers from the A1634770701 what i really need to know is that did A1634770501 replace the 0201 and i dont need any other parts to replace..
ml320red is offline
post #4 of 19 (permalink) Old 01-12-2009, 05:29 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
http://www.benzworld.org/forums/w163...305-306-a.html
Check out the above post. It has the VIN range that needs the fuel filter retrofit. If your ML falls in that range, you can get the filter and 2 new fuel lines at autohausaz. It is unlikely you will need the tool to release the tabs on the fuel lines.
Mike
Michael Pillay is online now
post #5 of 19 (permalink) Old 01-12-2009, 08:52 AM
Quoted: 35 Post(s)
Well if the part numbers are different, the parts are at least somewhat different. What I'm saying is that if you previously had the A163 477 07 01 filter filter, you can't get that any more because it has been replaced with A163 477 07 01 which is the one you should buy now.
The two parts I mentioned in addition, you would need them only if you had had an older filter. Those should already exist in your car, installed along with the filter you now had.
post #6 of 19 (permalink) Old 01-12-2009, 09:00 AM Thread Starter
are you kidden me!!, dude VIN #'s are not going to help, they dont change vin#s after the car has been sold and filter has been changed.
what im asking here is do i need other lines to use the A1634770701 i HAVE A1634770501 on my ML320 right now, NO I DO NOT HAVE THE DISCONTINUED A1634770201.
seems to be not much mercedes experts in here!!
ml320red is offline
post #7 of 19 (permalink) Old 01-12-2009, 09:35 AM
Kajtek1's Avatar
Quoted: 1167 Post(s)
The DieselBenz explanation are quite clear to me, so don't know where the confusion is coming from?
I just had identical situation on my E320cdi. The new filter had different number than the old one, but it was exact fit on the car. I assume the difference was in filtering material inside.
Kajtek1 is online now
post #8 of 19 (permalink) Old 01-12-2009, 10:22 AM Thread Starter
take a look on what DieselBenz last post again, his #'s are wrong in his explanation..read it.
ml320red is offline
post #9 of 19 (permalink) Old 01-12-2009, 10:35 AM
Kajtek1's Avatar
He was just giving you a sample, not your individual solution.
If you can't compare those 2 filters, maybe going to mechanic would be better solution?
post #10 of 19 (permalink) Old 01-12-2009, 10:50 AM Thread Starter
hmmm! maybe if ya dont know dont answer ,saves a whole lot of time..
ml320red is offline
    Installation instructions for ML320 Fuel Pump sesproul W163 M-Class 45 09-07-2015 04:12 AM
    02 ML320 fuel pump problem? stojakovic W163 M-Class 5 02-26-2009 06:45 AM
    Fuel Pump for MY2001 ML320. benjaminl W163 M-Class 0 03-21-2007 09:34 PM
    '98 ML320 Fuel Pump Replacement Cost elk127 W163 M-Class 7 02-12-2007 06:33 PM
    How to replace the Fuel Pump in a ML320 sesproul General Mercedes-Benz 4 10-31-2005 12:22 PM
