Sensor problems - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-11-2009, 03:12 AM Thread Starter
Date registered: Jan 2009
Sensor problems
Hi, i have a c200 kompressor which keeps showing an open engine bonet malfunction but bonet is closed any clues and also when starting the engine there is a clicking noise which lasts a few seconds is this the climate control or something more sinister?
toothnurse is offline
post #2 of 2 (permalink) Old 01-11-2009, 05:42 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
The bonnet open warning must come from the switch that detects if the bonnet is open (part of the alarm system). An E-class owner had a similar issue recently. You would have to check that the switch is operating properly. It could be the switch itself or the mechanical adjustment for the switch or a wiring/connector issue.
The engine noise could be almost anything. I'd guess valve lifters. When did you change oil last time and what kind of engine oil do you have?
Diesel Benz is offline
    Oil Level sensor problems?? jskins2000 W203 C-Class 3 09-20-2008 11:09 PM
    Change of Fuel / O2 Sensor problems oztds R170 SLK-Class 4 02-07-2007 02:11 AM
    Weird noise and sensor problems bronze560SEL W140 S-Class 0 09-27-2004 03:05 AM
    Rain-sensor problems JQ General Mercedes-Benz 5 01-12-2003 09:39 AM
    MAS sensor can cause LOTS of problems! (more) Dennis (Boston area) R170 SLK-Class 4 02-27-2002 05:04 AM
