Issue with reverse - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-08-2009, 09:48 PM Thread Starter
Date registered: Jan 2009
Issue with reverse
Hi all, new here.
I've got a 90 420SEL, and to be honest, it's in rather bad shape. There are a number of problems, but most distressing is an almost total lack of power in reverse. It's been going downhill for some time now and at this point getting it to back up at all is a hit or miss affair. With the car in reverse I can apply the gas and the engine kicks in but I generally have to get it up to at least 6000rpm to get any motion at all, and that's on a level surface.
I figure it has to be something with the transmission, but don't know much beyond that. I'd appreciate any ideas.
cugamer is offline
post #2 of 3 (permalink) Old 01-09-2009, 05:10 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
Its a bad trans the front clutch pack is worn to the point of slippage, trans has to come out. A dealer (MBfactory) rebuilt is more than your car is worth, maybe you can find an experienced rebuilder.
Peter Guenther is offline
post #3 of 3 (permalink) Old 01-10-2009, 08:53 PM
dseretakis's Avatar
Date registered: Nov 2006
Yup, reverse is the first to go. You could probably drive the car like that for quite a while till other gears start slipping. You just have to strategically park so that reverse becomes unnecessary.
dseretakis is offline
    no reverse / jerks in reverse when cold datpet07 W140 S-Class 30 12-11-2008 05:54 PM
    no reverse / jerks in reverse when cold datpet07 General Mercedes-Benz 0 11-09-2008 01:18 AM
    Brake-light issue leading to BAS/ESP issue??? Isoplus R170 SLK-Class 7 06-17-2006 12:57 PM
    reverse issue 240Drichard1982 W123 E,CE,D,CD,TD,TE Class 2 05-21-2006 07:46 AM
    83 380sel reverse issue BigBenz W126 S,SE,SEC,SEL,SD,SDL Class 3 05-05-2004 06:53 AM
