Problem with my newly ordered 07 S600 key - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 01-06-2009, 10:11 PM Thread Starter
In2MB's's Avatar
Date registered: Jun 2007
Vehicle: 2007 MB S600, 2003 MB S430 Graphite Designo, 2001 MB E430, 1999 MB E430
I recently picked up an extra key to my 2007 S600 from my local Mercedes Center. They told me that the key would be fine and is already programmed.
I got home this evening, and the key locks and unlocks the car perfectly. But when I tried to start the engine it said to remove the start engine button and place key or something to that nature.
My question is...........Has anyone else had this problem with a newly ordered key? The dealer saying it will work fine and it doesn't.
Thanks in advance
In2MB's is offline
post #2 of 6 (permalink) Old 01-06-2009, 10:31 PM
Date registered: Sep 2007
Maybe best bet is to go back to the dealer and let them do it, you have paid for the key and it should work fully. It will also save you messing something else up.
pavtoor is offline
post #3 of 6 (permalink) Old 01-06-2009, 11:23 PM Thread Starter
In2MB's's Avatar
^^ That is just what I planned to do. Like you said, I paid for it.
In2MB's is offline
post #4 of 6 (permalink) Old 01-07-2009, 02:41 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Thanks in advance
Do you mean you did not put the key into the ignition slot even if the car asked that? Are you assuming it would keep doing that which would be an issue?
I understand the key is fine as the dealer says except that it needs to be synced first, once.
Diesel Benz is offline
post #5 of 6 (permalink) Old 01-08-2009, 01:32 PM Thread Starter
In2MB's's Avatar
Tried that after I left the dealer the 1st time.....
I had already did what they and the car told me to do, nothing happened. When I went to the dealer yesterday, they tried to do same thing I did. There is a small bump on the back which I showed to them when picking up the key, therefore they think that the key was probably damaged because the box that they showed me yesturday was crushed pretty bad. They told me that is the way the box came to them and that I wasn't supposed to be called due to them expecting damage had been done to the key. They appolgized and another key is being ordered. So hopefully the next key will be fine. After I thought I had done something wrong, there's a problem with the key.
In2MB's is offline
post #6 of 6 (permalink) Old 01-08-2009, 09:54 PM
Quoted: 39 Post(s)
I see, it was not obvious from your post if you had inserted the key or not.
Bad luck with the part, hopefully a good key next time.
    Just Ordered New Key '91 300CE W202 C-Class 21 06-15-2009 02:05 AM
    JUST ordered my new S600-style grille :-) S320_on_18s W140 S-Class 7 02-22-2007 03:51 PM
    New key for 1994 S600 Barx W140 S-Class 4 12-05-2006 11:16 PM
    1994 S600 lost key problem Barx W140 S-Class 2 10-04-2005 01:08 AM
    Tire problem on newly purchased Starmark ML jwalther W163 M-Class 7 08-12-2004 04:44 AM
