oil in the coolant - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-06-2009, 06:11 PM Thread Starter
Date registered: Jan 2009
oil in the coolant
Hello, I have a very low mile 1994 c 280, that we discovered the waterpump was leaking externally, then we noticed oil in the coolant, first thought was cracked head, but doesn t overheat good heat in cabin, no coolant in the oil, runs like new, has anyone encountered this, I was told it could be the oil cooler seals are bad, any help out there??
etomco is offline
post #2 of 3 (permalink) Old 01-06-2009, 06:46 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Head gasket? I don't think the oil cooler is liquid cooled so it wouldn't mix coolant and oil. Water pump bearing lubricant? It's possible to have oil in the coolant without having coolant in the oil. Casting flaw in the head? It could be any number of possibilities. The block and head are the only places in a stock engine where coolant and oil are nearby one another and can mix.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #3 of 3 (permalink) Old 01-06-2009, 08:02 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
The head gasket on that engine is known to have some issues if it was not replaced with a later design gasket.
stox is offline
    Oil in the coolant, but no coolant in the oil Rickysa R/C107 SL/SLC Class 6 12-23-2008 09:51 AM
    Coolant in oil 4liter W126 S,SE,SEC,SEL,SD,SDL Class 18 11-27-2006 10:46 AM
    coolant in oil.....????? scottb W124 E,CE,D,TD Class 9 04-30-2006 11:31 AM
    oil in the coolant flathman W124 E,CE,D,TD Class 6 07-30-2005 07:00 PM
    oil in the coolant xmanmta W126 S,SE,SEC,SEL,SD,SDL Class 3 06-11-2005 01:05 PM
