Blown Engine 3.0 ltr CRD - Page 2 - Mercedes-Benz Forum
post #11 of 22 (permalink) Old 01-03-2009, 07:40 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Originally Posted by mr.xpowerseller View Post
68350 miles in 3 years?? That could be the cause of the failure.
Nonsense.
flyboyike is offline
post #12 of 22 (permalink) Old 01-03-2009, 10:37 PM Thread Starter
jenkomagic's Avatar
Date registered: Jul 2007
Vehicle: Mercedes Benz 500 SEL Euro 1986, Jeep Grand Cherokee 3.0 CRD
To set the record straight regarding my "speedometer reading". I live in Australia so we use kilometres NOT miles.
I have completed 110,000 kilometers in 3 years
jenkomagic is offline
post #13 of 22 (permalink) Old 01-04-2009, 01:18 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Originally Posted by jenkomagic View Post
People FYI,
Apart from contributing to this forum in the W126 section with my loved 500SEL, I also own a 2005 WH 3.0 CRD Jeep Grand Cherokee.
The engine in my Jeep is the same engine used by Mercedes in its ML, C, S E range.
At 110,000 kms (3 years ) I have had a catastrophic engine failure melting a couple of pistons in the process.
I am currently in a battle with Chrysler Australia as vehicles basic warranty has expired and they are not providing financial assistance.
Apparently the ECU controlling the injectors has failed. This can be extremely dangerous in a common rail diesel engine with the immense pressure in the common rail.
I may even contact Mercedes Australia for their thoughts.
Jeep OZ have told me this has happened once before I was wondering if any Mercedes owners have had a similar experience
Do you mean they report other ECU failures or other engine failures like yours? I cannot think of an ECU failure that would exist and let the engine run long enough to cause any mechanical failures.
The higher pressures at the rail are normal on all CDIs, not a source for engine failures. Perhaps you mean an injector failure of some kind? They should have figured this out at when the car was serviced.
Diesel Benz is offline
post #14 of 22 (permalink) Old 01-04-2009, 01:29 AM Thread Starter
jenkomagic's Avatar
Your right my mistake when explaining possibly injector failure however with the high pressure of a common rail a "leaky" injector can cause a world of hurt in a CRD.
post #15 of 22 (permalink) Old 01-04-2009, 12:38 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
And how is that different than 68350 miles?
And your speedometer doesn't measure accumulated kilometers or miles. Your odometer does.
mr.xpowerseller is offline
post #16 of 22 (permalink) Old 01-04-2009, 03:36 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Originally Posted by Kajtek1 View Post
Sounds like the engine might be a sibling of 320cdi sold in big numbers in USA?
The only problem I had with mine was leaky injector seal, what I posted in W211 section.
Good luck on your claim.
His is the V6, i.e. OM642, not the inline 6 (OM648) that you have.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #17 of 22 (permalink) Old 01-04-2009, 03:37 PM
Quoted: 2 Post(s)
68350 miles in 3 years?? That could be the cause of the failure. These are not commercial vehicles. Were you delivering packages or mail with this truck of what?
Same engine is installed in Sprinter vans.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #18 of 22 (permalink) Old 01-04-2009, 11:29 PM Thread Starter
jenkomagic's Avatar
your point is irrelevant to this thread
post #19 of 22 (permalink) Old 01-04-2009, 11:31 PM Thread Starter
jenkomagic's Avatar
http://www.wkjeeps.com/tsb/tsb_wk_0900108.pdf
http://www.wkjeeps.com/wk_crd.htm
Has Merc ever had problems with main bearings with this engine or had a recall?
post #20 of 22 (permalink) Old 01-05-2009, 09:41 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 379 Post(s)
are you serious???? I've put 70K on my silverado duramax diesel in 3 years as a personal vehicle just on vacations and other driving. (and 0 problems by the way) high miles/yr shouldn't have anything to do with engine problems as long as proper maintenance is done. with todays manufacturing processes and lubrications, ANY well designed engine should be capable of at least 200K miles without major problems.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is online now
    Blown '63 engine lear31a driver W211 E55 AMG, E63 AMG 10 12-14-2006 08:24 PM
    The first 6.3 AMG engine blown up !!! linh R170 SLK-Class 10 11-27-2006 05:06 PM
    blown engine! AMG! W211 E55 AMG, E63 AMG 11 08-06-2004 09:57 PM
    blown SEC engine amgbnz W126 S,SE,SEC,SEL,SD,SDL Class 22 06-04-2004 06:21 PM
    Blown engine Guest (MBNZ) W210 E50 AMG, E55 AMG 7 03-08-2002 10:26 AM
