staggered rims for 2000 170 class - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-30-2008, 08:08 PM Thread Starter
Date registered: Dec 2008
Vehicle: 2000 SLK 230 Limited Edition
Question staggered rims for 2000 170 class
I've got 225/45/17 all the way around on my 230 and want to put 225/40/18 front and 255/35/18 on the rear. Are there any concerns I should consider?
Fred Wheeler is offline
post #2 of 3 (permalink) Old 12-31-2008, 02:58 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Welcome to the forum, Fred. FWIW there is a tire and wheel tech forum as well as a forum focused on the 170, so I'd guess you will probably get more pointed information in there as opposed to this general forum.
That said, there is nothing wrong with a staggered wheel setup on the non-4matic cars. The two primary concerns are width and OD on the tire size and offset on the wheel size. For a rough guide on tire OD you can use one of the calculators such as the one at tire1010.com or miata.net/garage/tirecalc.html In this case your OD is almost equal, so those sizes in a generic sense are fine.
My suggestion would be to work with a trusted tire and wheel vendor to ensure that first and foremost, you get quality tires and wheels that will not create safety, balance or handling problems of any kind for you. The second reason is to be sure that everything fits properly and that if there are any fitment concerns, the vendor has to make it right. Thus stick with someone you know or who has been recommended to you, so with that in mind I would steer you as far away as possible from ebay vendors and the like. The few dollars you save won't mean that much if problems arise.
Take care and enjoy the ride,
Greg
Check Codes is offline
post #3 of 3 (permalink) Old 12-31-2008, 09:30 AM Thread Starter
Thumbs up
Greg
Thanks for the guidance on Tech Forum and the wheel info. I appreciate your candor!
Fred
    FS: OEM 18" E55 AMG rims and tires. Staggered rims 6speedRUS For Sale/Wanted/Trade/Giveaway 7 03-07-2009 07:04 PM
    New SLK Grill three rips and chrom rims R 170 verimexx R170 SLK-Class 5 07-16-2007 01:06 AM
    170 Rims??? Opinions??? Newbee R170 SLK-Class 10 06-12-2005 07:32 PM
    2000 S-Class 18"AMG Staggerd Rims/Xenon Lights and TailLamps 4 Sale!! dtxmob W220 S-Class 2 01-17-2005 04:34 AM
    2000 C class sport rims and tire if possible rlagm3 W202 C-Class 1 09-02-2003 05:26 PM
