300 SDL priming pump? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-30-2008, 07:47 AM Thread Starter
Date registered: Dec 2008
Post 300 SDL priming pump?
My SDL starts perfectly, even in extreme cold, then after a few seconds begins missing and smoking for 30 seconds or so. After that it runs perfectly. I'm thinking this sounds like the priming pump problem? I hate to spend the $ for a priming pump without some expert opinions. Does this sound like a priming pump issue or is there a check valve somewhere that is allowing fuel to drain back when the engine sits for a while? Also, if I were to put an inline electric pump, would that fix the priming issue. Thanks
DLieder is offline
post #2 of 5 (permalink) Old 12-30-2008, 09:21 AM
Kajtek1's Avatar
Quoted: 1166 Post(s)
What year?
Your symptoms are like leaks in the fuel lines let the air in over the night.
Welcome to the forum.
Kajtek1 is online now
post #3 of 5 (permalink) Old 12-30-2008, 12:33 PM Thread Starter
Thanks for the welcome, and sorry to take so long getting back to you. The Benz is an 86. And yes, I also think it sounds like air in the system. It runs like it is priming during those 30-45 seconds. Can you think of a likely place to look, where air could be introduced to the fuel system without also leaking fuel or fuel smell? I recently had the fuel lines and injectors off and hoped my problem would go away. No luck. The good news is that the problem is so fleeting that I can easily live with it... I'm just a bit embarassed by the smoking when it starts up after sitting.
Thanks again.
DLieder is offline
post #4 of 5 (permalink) Old 12-30-2008, 07:15 PM
Kajtek1's Avatar
If I recall it correctly your engine is having rubber hoses carrying fuel from the tank to the priming pump, that rubber hoses connecting to the prefilter, than rubber hose going to main filter and that's where the solid tubing start?
I would start with replacing badly looking rubber hoses or at least checking the clamps. Torquing metal connectors might be good idea as well.
post #5 of 5 (permalink) Old 12-31-2008, 07:13 AM Thread Starter
Thanks, I'll start looking in that direction. I really didn't want to spend the money on the priming pump unless there was a good chance that was my problem... so thanks for directing me away. You are right, my car has rubber hoses, as I recall, all the way to the pump. I have never fiddled with them so that would be a good place to start. Have a great holiday.
DLieder is offline
    Priming pump for '79 300 diesel engine hopefunfun Vintage Mercedes-Benz 1 08-04-2008 03:19 PM
    300 SDL 87 INJECTION PUMP jeanclaude8273 W126 S,SE,SEC,SEL,SD,SDL Class 3 06-27-2008 11:31 PM
    changing priming pump jets4 W123 E,CE,D,CD,TD,TE Class 0 05-07-2005 01:27 PM
    Model Year Picks for Mercedes 300 SDL/350 SDL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-20-2001 04:34 PM
    Model Year Picks for Mercedes 300 SDL/350 SDL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-20-2001 04:31 PM
