My 1st MB: an '86 300 SDL - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-21-2008, 03:22 AM Thread Starter
Date registered: Nov 2008
Vehicle: '86 300 SDL, Nautical Blue/Java
Cool My 1st MB: an '86 300 SDL
I'm in my 20s and just picked up my first MB, a clean Nautical Blue/Java 300 SDL with about 260k. As a lifelong resident of southern CA, I wanted a local example (i.e. no rust issues), and I found a 1-owner right here in Pasadena. A few issues (mainly the electrics) are presenting themselves. So ANY info on these V126s, particularly the 300 SDL, would be truly appreciated. Other than knowing that it's rated @ 143 hp (CA version) and about 201 lb/ft torque, I'm fairly clueless. Any info or links to articles (Car & Driver, Road & Track, or other) would help me to better understand my new toy.
By the way, the electrical issues I need help with are:
sunroof (tilts, but no longer slides- occurred since purchase [motor still works])
window switches (all 4 near the gearshift have fallen loose from their cradles in the wood console. Do I need to find a salvage console for my existing switches?)
slow/intermittent rear passenger window (switch contact, vacuum, or both?)
interior lights (none work but the one nearest sunroof button, but I haven't checked bulbs)
light display @ sunroof switch/reading light assembly (blank, no lights at all. Easy fix?)
power seats [fronts only] (work ONLY when their respective door is open, and headrests don't go up/down electrically, yet memory still works)
tranny (1-2 shift is pretty decent, but the 2-3 and 3-4 occur with a slam. How much can this be softened (but not damagingly OVER-softened) by altering its vacuum control?
General questions I have:
Does this car have an LSD rear end?
How often (miles) should I change the oil?
Living in warm SoCal, is a conversion/separate fuel cell necessary should I wish to partially mix Veggie Oil into the factory diesel set-up?
Thanks, in advance, for anything you can offer whatsoever.
P.S. I ran the VIN through the Russian site, and I'd be happy to post the equipment findings if that's helpful with any of the above.
V126 Fan is offline
    What should I do with my 87 300 SDL? nbv4 W126 S,SE,SEC,SEL,SD,SDL Class 9 11-20-2008 09:06 AM
    87 300 sdl Gundog General Mercedes-Benz 0 01-12-2008 06:06 PM
    87 300 sdl FAULKER W126 S,SE,SEC,SEL,SD,SDL Class 1 09-06-2007 08:02 PM
    Model Year Picks for Mercedes 300 SDL/350 SDL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-20-2001 03:34 PM
    Model Year Picks for Mercedes 300 SDL/350 SDL Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-20-2001 03:31 PM
