my Ml-320 rumbles under braking - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 12-18-2008, 06:00 PM Thread Starter
Date registered: Dec 2008
Post my Ml-320 rumbles under braking
I need help please.
I plan on taking a trip this weekend. my problem is when I apply my brakes several times and they heat up the car starts to rumble or pulsate only under braking, but I don't feel it in the steering wheel but in the chasie. I was first told it was the front rotors but no change. Today I had rear rotors replaced and no change. If I drive a few miles without using the brakes then apply them it is gone. All I have to do is brake from 60 down to 30 three times in a row again, the breaks heat up and it rumbles again, of course only under braking.
Any ideas?
rockster is offline
post #2 of 2 (permalink) Old 12-18-2008, 10:16 PM
nlehre's Avatar
Date registered: Feb 2008
Vehicle: 2005 SL500, 2011 GL350
How many miles on your vehicle? When did you replace the pads? Did you use original equipment pads and rotors? Mercedes engineers the brakes and rotors with specific material properties to produce specific braking performance. If you use non-stock pads and/or rotors, you could get undesireable side effects when braking, in your case when the brakes heat up. Maybe when your pads and rotors heat up, they produce uneven braking which could cause a rumble. When was the last time your changed your brake fluid? It's supposed to be changed every two years. If it hasn't been changed for a few years, it can absorb moisture which causes hydraulic issues when the fluid heats up. There are many variables here so you need to tells us exactly what has been done with your brake system in terms of maintenance and any repairs.
Neil
San Francisco Bay Area
2007 E550, P1, Sport
1996 SL320, ASR, Heated Seats, Xenons, CD Changer,
My Cars: http://www.benzworld.org/gallery/sho...&ppuser=133412
nlehre is offline
Braking vs Engine Braking Darkmann W163 M-Class 17 07-28-2008 07:42 AM
improved braking for ML 320 ranmac W163 M-Class 8 05-23-2008 07:16 AM
Check Engine Light is ON and car rumbles... EUROSOE W203 C-Class 9 01-14-2007 10:42 AM
braking by itself? sin0822 W163 M-Class 7 04-15-2006 09:57 PM
braking hans R170 SLK-Class 4 04-28-2002 02:52 AM
