To the self-considered Benz Guru - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-18-2008, 08:49 AM Thread Starter
Date registered: Jan 2008
Vehicle: 99 c230k
Kay, Ill try and keep this short.
So on my way home from lethbridge to saskatoon, my Check Engine Light went on while i was driving at 120km/h. The car drove smooth, everything was in check, no high temps. So I stopped in the next town, and when the car is idle it's vibrating slightly. It would vibrate in D or P or R. So I turn it off, turn it back on and no vibration. I keep driving and under heavier acceleration the car will get this jerky, vibrate feeling, so I layed off that. It will only vibrate at a stop after Ive been driving for a decent distance already, and under heavy acceleration.
I took it to the benz dealership when I got back in saskatoon. They scanned it and it came up with 2 codes, P0300-080 (misfiring damages TWC),whatever that means, TWC? and it came up with P0304-083 (misfiring of cylinder 4 : 83.
The tech told me to start with the spark plugs, as they shouldnt go further than 4 years. Ive had the car for 1, so i dont know when they were last replaced. But why does the car stop vibrating in idle when i turn it off and restart it.
Also leaving the dealership the CEL was off, and as soon as I accelerated at a decent rate, it came back on, and I vibrated at the next red light.
Any opinions on all of this guys??? Other than spark plugs so I can cover all my bases.
What I don't understand is, how could this be a spark plug problem, if when I turn the car off and on the problem goes away until heavier acceleration? I would think this would have to be some sort of a reset thing like a MAF, as far as i know plugs dont "reset".
This forum gets alot more traffic then mine so i thought i might as well ask here too.
chong188 is offline
post #2 of 10 (permalink) Old 12-18-2008, 09:07 AM
Kajtek1's Avatar
Quoted: 1068 Post(s)
If you have "shorter" version of the 320 engine so popular in US -the MAF would be the first suspect. IMHO with MAFs available below $100 that is still cheaper than reading codes at dealer.
Good luck.
Kajtek1 is online now
post #3 of 10 (permalink) Old 12-18-2008, 09:19 AM Thread Starter
Vehicle: 99 c230k
yah maybe ill order a new maf from autohauz, but the benz dealership here I am so impressed with, they didnt charge me a thing to hook up and pull the codes, and im not under any warranty at all. Good folks down there.
chong188 is offline
post #4 of 10 (permalink) Old 12-18-2008, 09:42 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 353 Post(s)
My brother had a similar problem and error codes on the E-420 I bought from him. Ended up being a intermittent coil for one cylinder. Once a misfire is detected if it continues fuel is shut off to that cylinder until restart, supposidly to keep from damaging the cat. That is why it goes away on a restart for a while. One thing to try is to swap the coil with another cylinder and see if the code continues but with the new cylinder.
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is online now
post #5 of 10 (permalink) Old 12-18-2008, 09:45 AM
Date registered: Feb 2003
Just went through this with our VW
A coil failed ie the electronic version of the distributor cap. In my case the I started noticing a small hesitation once in a while under heavy acceleration. Then poof about two days later the engine light came on and I had one cylinder that wasn't getting a spark so naturally the engine ran like crap. Low speeds you will get heavy vibration then as the non functional cylinder picks up speed the vibration goes away. The VW had one coil for each plug - they are like other electronic stuff some times they last years and years some times they just fail no reason etc. But when one coil fails VW mechanic said normally the others aren't to far behind.
Start simple and work your way up to the more complex. My guess is that the spark plug is probably OK but you could have a loose or bad wire if those things check out look into the coil as a possible culprit. Not sure if there is an easy way to test each part but my guess is there is an easy check I just have never done it.
Good luck
TW10 is offline
post #6 of 10 (permalink) Old 12-18-2008, 10:36 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
P0300 is just a general random misfire. P0304 is misfire on cylinder 4. As suggested, change your plugs. I am not sure if you need to do anything with the MAF. Problems with that usually throw the codes P0170 and P0173. I would suggest you get some CRC MAF cleaner and clean it. I think changing the plugs will take care of the main issue. Good luck.
Michael Pillay is online now
post #7 of 10 (permalink) Old 12-18-2008, 11:55 AM Thread Starter
Vehicle: 99 c230k
alright will definitly do that, but another question, do i have to use the OEM bosch ones, because the benz here doesnt have any in stock and i dont want to wait for them to come in from vancouver so i was wondering if its okay to use an AEM spark plug?
chong188 is offline
post #8 of 10 (permalink) Old 12-18-2008, 04:11 PM
Palm Beach Henry's Avatar
Date registered: Jul 2008
Vehicle: C 230 1997 42000 miles
I vote for coil.
You may have a hairline crack in your coil. This happened to me. My indie showed me the coil and the crack was barely visible to the naked eye. Both my coils had to be changed.
Palm Beach Henry is offline
post #9 of 10 (permalink) Old 12-18-2008, 11:10 PM
nlehre's Avatar
Date registered: Feb 2008
Vehicle: 2005 SL500, 2007 E550
This could be something as simple as a bad batch of gas. I used to have an Audi that was very sensitive to bad gas which would cause a cylinder misfire code. Once in my Explorer I got a bad batch of gas which created hard starting problems. Did you gas up in Lethbridge at a place you don't normally use? An offbrand cheapo gas station by any chance?
San Francisco Bay Area
2007 E550, P1, Sport
1996 SL320, ASR, Heated Seats, Xenons, CD Changer,
My Cars:
nlehre is offline
post #10 of 10 (permalink) Old 12-19-2008, 08:24 AM Thread Starter
Vehicle: 99 c230k
I filled up in lethbridge at the esso, 91 oct premium, then in swift current, i had a half tank left and filled back up at shell with the v-power. So it wasnt like a no name convenience gas store, but who knows maybe it is gas. Maybe Ill fill back up and see what happens, im at half tank again.
chong188 is offline
    Need help from a brake guru phyxer W123 E,CE,D,CD,TD,TE Class 8 08-09-2008 12:35 PM
    Guru Needed sparcolite R170 SLK-Class 13 04-03-2008 08:34 AM
    Guru needs help! Steve Johnson R170 SLK-Class 8 03-21-2007 03:52 PM
    New to Benz... need guru to guide me on my search. geekcomputing Vintage Mercedes-Benz 2 04-19-2006 10:24 AM
    The Mercedes-Benz W123 family is now officially considered "classic" according to Mercedes... 190E2.6 W123 E,CE,D,CD,TD,TE Class 4 02-18-2003 07:55 AM
