722.6 Trans disassembly/ rebuild help - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-16-2008, 07:26 PM Thread Starter
Date registered: Nov 2008
Ok so A friend of mine dropped this trans off for repair.
Trans was said to be slipping. Dissassembling unit for repair need to know how to remove the valve body without destroying the electronics connector.
While I'm at it does anyone know specs for various clutch pack clearances and buildups. Service info.
rapidtransit is offline
post #2 of 7 (permalink) Old 12-17-2008, 04:43 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
In all due respect. If you dont know how to take one apart, what makes you think you can rebuild it. The dealerships dont even repair them. The MB dvd does not even discuss rebuilding them, maybe ALL DATA.
If you are a trans rebuilder some parts suppliers have limited information
Peter Guenther is offline
post #3 of 7 (permalink) Old 12-17-2008, 08:05 AM Thread Starter
Well lets see Just finishing up a rebuild on a Ford 4r70w over drive trans, and a 2004 Caravan Transaxle as well as many others in the past.
I've spent 10 yrs as a Diesel mechanic repairing injection pumps and such.
Oh I've also repaired drivetrains in heavy equipment (dozer and excavators) as well hydraulic pumps.
Spent time with the miles (and many hundreds of pounds) of wiring inside a city bus as well as the computors which control it.
You asked and I'm qualified.
I felt someone here may have had a bit of knowledge about this particular unit. The valve body is somehow attached to the wiring harness connector which is unseen from the backside.
In order to perform a proper rebuild the valve body must come out. Shure I can remove it if I use gorilla force then replace the harness after the fact.
When in doubt ask.
Yes Alldata may be one source. I also felt this site could be one of them perhaps a better one.
post #4 of 7 (permalink) Old 12-17-2008, 08:09 AM Thread Starter
Ya know what I also worked for a dealership ( not benz ) at one time and I know many places that would perform the same work as well or better in many cases.
post #5 of 7 (permalink) Old 12-19-2008, 07:38 PM
Richard ML 350's Avatar
Date registered: Sep 2004
Vehicle: 2004 ML 350
There is a guide bushing which connects the wiring harness to the 13 pin connector on the transmission ECU. Once you unplug the connector, the rest of the electronics tray is held onto the valve body by three screws which also hold the solenoid valve leaf springs in place. Remove those, and the tray should lift off. I have diagrams but the file sizes are large.
Richard ML 350 is offline
post #6 of 7 (permalink) Old 12-19-2008, 07:45 PM
bsmuwk's Avatar
Date registered: Jun 2008
Vehicle: Depends on the week
Quoted: 37 Post(s)
When in doubt ask.
Just dont forget you're working with a Mercedes. Good Luck with the rebuild.
☆ ★ A R T I S A N ☆ ★ ☆ ★ A R T I S A N ☆ ★
Chicagoland Mercedes Facebook Group: https://www.facebook.com/groups/mbclubchicago/
Join the W124 Buy/Sell/Trade/Chat Group on Facebook : https://www.facebook.com/groups/224626884381433/
http://artisanexcite.blogspot.com/
Mercedes Diesel Injector Servicing: http://artisanexcite.blogspot.com/p/...servicing.html
bsmuwk is offline
post #7 of 7 (permalink) Old 12-20-2008, 05:21 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
I do not know if this will help, but there are a few clips of rebuilding a 722.6. Here is the first:
YouTube - Mercedes 722.6 Transmission - ML 320
OdinAF likes this.
Mike
Michael Pillay is offline
difference between 722.350 and 722.323 trans lander91 W126 S,SE,SEC,SEL,SD,SDL Class 7 04-11-2010 04:11 PM
Hello 722.631 722.6 trans problem mb98c43amg General Mercedes-Benz 0 08-27-2008 08:21 PM
Rebuild my trans. or swap an already rebuilt trans. Poll maharodger W202 C-Class 13 09-30-2007 06:02 PM
722.4 rebuild cost lovemyc280 General Mercedes-Benz 15 03-20-2007 07:05 AM
722.4 rebuild lovemyc280 W202 C-Class 3 03-16-2007 06:40 PM
