Slightly overfilled transmission fluid - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-16-2008, 05:33 PM Thread Starter
Date registered: Dec 2008
Vehicle: 1986 C300 Mercedes
In over a year, my dear old 89 300C (142,000 miles) twice has had an odd release of transmission fluid while standing in the carport. When refilled it is now about 1/2 to one pint overfilled. Running fine and not leaking any longer. Do I need to have some of the fluid drained? I used Lucas transmission stop leak and about 1/4 pint of regular fluid as it showed empty on the stick.
Mahalo, Jeudi
Jeudis old Benz is offline
post #2 of 4 (permalink) Old 12-16-2008, 05:48 PM
Musikmann's Avatar
Quoted: 6 Post(s)
On my car, the ATF level is pretty critical. Find the model-specific forum for your car and ask the owners there. You are much more likely to get a quick and accurate answer than you are in the General forum. Good luck and welcome to Benzworld.org.
Musikmann is offline
post #3 of 4 (permalink) Old 12-16-2008, 06:47 PM
Kajtek1's Avatar
Quoted: 1168 Post(s)
Years ago I bought used W123 that had transmission overfilled by seller. It drove in the city just fine, but when I went on straight freeway about 20 miles later -the transmission fluid "boiled out" via the breathing tube. Splashing on the hot exhaust it made military-style camouflage smoke.
Scarred me to death, but after pulling over and checking what happened I drove it for thousands of miles without problems.
Sure you don't want to take chances with computerized transmissions, but I wouldn't exaggerate the danger.
Kajtek1 is offline
post #4 of 4 (permalink) Old 01-12-2009, 12:47 PM Thread Starter
My car is running great even though the fluid level hasn't gone down. Guess the Lucas transmission leak actually works. Now all I need is to get the air conditioner fixed, any suggestions?
    Transfer Case fluid and Transmission Fluid clb0099 W163 M-Class 4 01-12-2008 09:59 PM
    Transmission Fluid Change, how much fluid? slk230red R170 SLK-Class 5 03-07-2007 10:06 PM
    How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 11 08-17-2006 05:31 PM
    Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 11:59 AM
    Transmission fluid change - what fluid ???? Anjey W126 S,SE,SEC,SEL,SD,SDL Class 9 05-10-2005 01:18 PM
