Possible fuel pump failure C180, 2001 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-15-2008, 10:31 AM Thread Starter
Date registered: Dec 2008
My 2001 C180 was driving as usual when I stopped but then when I tried to start up again the engine appeared to fire then died. Seems like fuel starvation but there was no warning. Does anyone have any thoughts? I'm told it could be the fuel pump but I am also told the pump is really reliable. Certainly I can't hear any noise from the pump but it would help if I could get the seat out to check. How does the rear seat come out? Seems to have hinges at the front but I cannot find any release mechanism to allow it to lift?
I'd appreciate any help you can give me.
johnj46 is offline
post #2 of 3 (permalink) Old 12-17-2008, 11:29 AM
Date registered: Mar 2008
Vehicle: 1999 ML320 1999 ML430 1984 Corvette 1959 Bel Air
Bang on the fuel tank then try to start the car if it starts its the pump failing I am having just that problem right now but I cant find the pump with the right plug to match the car
rayrod99m is offline
post #3 of 3 (permalink) Old 12-18-2008, 06:54 AM Thread Starter
Thanks for your help. I can't even find the fuel tank. I guess it is under the back seat but how does that come out? I've looked for release catches and tried just pulling it up but it seems to be held by something in the middle. I cannot here any noise like the pump working anywhere around the back of the car, in the trunk or near the back seat so I really want to get in there and hit the tank!
johnj46 is offline
    2001 C240 Brake light failure leading to ESP/BAS Failure lxshk Audio & Telematics Forum 1 08-04-2008 09:54 PM
    1995 C180 Fuel Pump Relay Switch Location artline W202 C-Class 2 05-19-2008 04:59 AM
    Fuel Pump/Sender Failure Poll gsj224 W163 M-Class 5 01-17-2008 04:27 PM
    A Fuel Pump Failure Survey Corsica W163 M-Class 19 11-28-2003 01:08 PM
    Fuel Pump Failure 00 ML430 Bulldog W163 M-Class 4 10-23-2003 10:03 AM
