Fuel Priming - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 12-11-2008, 08:00 PM Thread Starter
Date registered: Dec 2008
Question Fuel Priming
I've got a 300d with the white plastic primer handle. When I pump I get lots of fuel seems to come up the outside of the inner pump tube. Doesn't seem right! Does it?
sydney2000 is offline
post #2 of 3 (permalink) Old 12-11-2008, 09:08 PM
Kajtek1's Avatar
Quoted: 1058 Post(s)
What year is it? I believe hand pump become obsolete in 1986?
The fuel never suppose to leak outside, unless you open bleeding screw. If I recall the older engines had bleeding screw on the top of fuel filter.
Kajtek1 is offline
post #3 of 3 (permalink) Old 12-12-2008, 05:48 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Primer pump needs to be replaced. Easy $20 job.
sokoloff is offline
    Priming new fuel filter Zill R170 SLK-Class 3 09-19-2008 07:19 AM
    Priming Fuel System 112CDi RHKVito V-Class 4 11-25-2006 02:33 PM
    changing priming pump jets4 W123 E,CE,D,CD,TD,TE Class 0 05-07-2005 12:27 PM
    Priming the engine bahndo W123 E,CE,D,CD,TD,TE Class 2 01-19-2005 03:24 PM
    Priming the oil lubrication system silver_arrow R129 SL-Class 0 07-30-2004 11:52 PM
