Tranny fill Walkthrough - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-10-2008, 12:26 PM Thread Starter
Date registered: Dec 2008
Red face Tranny fill Walkthrough
Can anyone help me with an automatic transmission fill walkthrough? I received a 190e but the guy wasn't clear on the year of the car however I'm almost sure it's a '92. That said, the transmission fluid is low and I need to fill it. The trans dipstick has no fill markings on it either, which I find strange. Any help would be huge at this point. Also, I'm in Santiago, Chile. Just so you know. Thanks guys.
JOSEPH
Jahosafat is offline
post #2 of 4 (permalink) Old 12-10-2008, 03:04 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
On the W201, fluid level checks are done with the engine running, warmed up to normal temperature and the transmission in Park. There should be two engraved lines on the transmission dipstick a couple inches from the bottom. Those lines denote the minimum and maximum levels and there is a 0.3L difference between the two marks.
"Topping off" is done via the dipstick tube with a funnel. Go slowly and do not overfill beyond the maximum level indicator.
Before turning off the engine, with the brake engaged, move the shifter through all the positions, pausing briefly at each notch. Put the car back into park and recheck the trans fluid level again. If the level has lowered, add more fluid and repeat the process above.
MTI is offline
post #3 of 4 (permalink) Old 12-10-2008, 07:25 PM Thread Starter
the dipstick is broken.
looking for a new one...
post #4 of 4 (permalink) Old 12-12-2008, 01:42 PM
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
I did a DIY on this awhile ago. Do a SEARCH for my name and you'll see pictures on it.
It's really not that much different than any other car.
Your going to Drain all that old nasty fluid.
Make sure you use Factory Spec. Fluid. I used MERCON Dexron III for mine.
It met all the Specs. by MB.
I changed out the Filter
Used a Lint Free rag to clean the Pan and drippings
I replaced the Pan Gasket.
I filled it to the required amount.
CAREFULLY Check your Owner's Manual on this.
There's a FULL Tranny Changeout, Tranny plus Differential.
If you are doing that, it requires more Tranny Fluid.
If you are just doing the Tranny it will require less Fluid.
Fill it to EXACTLY, not an Ounce more than Required.
System will overpressurize and cause cascading problems.
I updated my Maintenance Log Book.
It's not as hard as you imagine.
Same as other cars.
JOSEPH
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
    Picture Posting Walkthrough. DIY! Kynyption W201 190-Class 11 07-01-2008 12:53 PM
    is it possible to suck my tranny oil out of the covered fill pipe? busoptr W163 M-Class 6 01-22-2007 02:36 PM
    Power Antenna replacement walkthrough? crate W123 E,CE,D,CD,TD,TE Class 1 12-16-2006 04:25 PM
    where do u fill the tranny fluid on the 5spd boxes? snik W140 S-Class 1 08-30-2006 09:35 AM
    Fill er up AMPM R170 SLK-Class 4 03-17-2004 09:51 AM
