Key turns off egnition while driving - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 12-08-2008, 01:56 PM Thread Starter
alexus.one's Avatar
Date registered: Jun 2007
Vehicle: C280 '97, SLK55 BRABUS AMG '05
Quoted: 2 Post(s)
Question Key turns off egnition while driving
So another key thret Not funny though.
I was driving and all over sudden the car stops in the middle of the road. Waht apeared to be the problem is that key wen from "ignition #4" position to the previous position #3 (i thionk the #s are correct) so my stearing wheal got locked and ignition stopped. I had semilar problem before.. and if that happand on highway i will get in trouble, so i wanna fix that ....
I also some times have trouble rotating the key from position 0, it feals like key is stuck. Also one side of the key is worn out so i only can use the key in position button down (Oh yes I have C280 '97 w/ IR + Mechanical key).
So maybe some one knows the best solution?
a) should i get new key insert? "Mech Blade"
b) should i take the key lock out and check strings or something?
I dont feel to good about messing with the key system so hope some one can help.
Thanks a lot!
alexus.one is offline
post #2 of 18 (permalink) Old 12-09-2008, 04:51 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
I would get a new key (cut) from dealer. I think it is held in the remote by a pin. Do you have a lot of junk hanging on your remote, the weight could turn it!
Peter Guenther is offline
post #3 of 18 (permalink) Old 12-09-2008, 07:55 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
I have nothing on the key at all... I keep the key by itself.
- i dont get what u say here... do u mean the key is held in the position 4 by pin? or something esle
Ok will try to go to the dealer to see if they can get me the key blade... hopefuly i dont have to buy 200$ key
post #4 of 18 (permalink) Old 12-09-2008, 11:10 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
Just came back from the dealer they parts guy told me they would cut the mech key for $12.50 Did i hear that right my house key costed me 15$ to duplicate lol, well i hope thats was not $120.... any way will wait fror the key and see if that would solve the problem... hope it will
post #5 of 18 (permalink) Old 12-09-2008, 11:18 AM
Kajtek1's Avatar
Quoted: 1248 Post(s)
I dealt with mechanical key/cylinder on 1997 E class. Even the new cylinders are pretty affordable -replacing them takes good trick. I managed to lock the wheel blockade and had to cut it off. Look for the thread in W210 section.
If you have just worn blade, but good cylinder the blade alone cost in $5 range at Duval. I am gettig house keys cut for less than $2.
Good luck.
Kajtek1 is online now
post #6 of 18 (permalink) Old 12-09-2008, 11:23 AM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
well i am relpacing the blade...
I hope I dont have to deal with cilinder... especially in the winter w/o garage
post #7 of 18 (permalink) Old 12-09-2008, 01:31 PM
Kajtek1's Avatar
Well.. worn blade would not turn the cylinder but it is cylinder and probably switch spring that holds the blade in position.
Good luck, sounds like you are going to need it.
post #8 of 18 (permalink) Old 12-09-2008, 08:53 PM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
ups replacing cilinfer may be a problem
so
a) how to i get to the cilinder?
b) how can i "harden the "string" to increase "firmliness" (um whats the right word) well the state of the key being more firm in position
c) and more over how can i test the results... so far i had like 4 incidents w/ key turning the car off during driving. and in all cases it was like i started the engine drow dowe for like 30 sec.. most of the time till the next full stom and once i press brake the key goes off... seems that it doesnt turn of while im driving (thanks god... knok knok knok) Under such rear symptoms i'm not sure how can i see if i made any goods in terms of repairing
post #9 of 18 (permalink) Old 12-17-2008, 03:08 PM Thread Starter
alexus.one's Avatar
Quoted: 2 Post(s)
So I got the key from the dealer.... guess what... it doesnt work
opens dooors, opens trunk, starts the ignition half way (test lights are on, but doesnt go into next position where engine actually starts
Dealer told me that cylinder is 130$
I see there are cylinders on the net for $50 but will the cheap one work? I would assume they will not configure it for me? So does it mean that I just have to go with dealer offer?
post #10 of 18 (permalink) Old 12-17-2008, 06:01 PM
Kajtek1's Avatar
I assumed the cylinder I bought for $59 was OEM cylinder, just not coming from the dealer.
Hard time is matching all locks on the car. Ask dealer if they can rekey the new cylinder to old key, so you won't have to deal with different keys for doors.
    Key turns, no starter tmehanna W204 C-Class 7 02-27-2008 09:56 AM
    Help:Car runs & then turns off will driving.Will crank but not start 007MB1 W210 E-Class 6 09-16-2006 01:34 AM
    Traction control ( ! ) turns on and off during highway driving... Anyone know whats up??? jtoma878 C208/A208 CLK-Class 2 10-24-2005 06:00 PM
    Egnition switch key wont go in. Jolinie W124 E,CE,D,TD Class 1 07-11-2005 12:00 AM
    Radio Turns On After Key Removed. JRussell R170 SLK-Class 5 06-21-2002 11:56 AM
