Engine problems...need help - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-06-2008, 12:20 AM Thread Starter
Date registered: May 2008
Vehicle: mb c200k
Hello everybody. I am quite new on this forum and, so far, I found very useful informations here. For that many thanks to everyone.
I have a problem now with my Mercedes c200 kompressor form 2001, automatic transmission.
3 months ago I had installed a LPG kit on my car. Since then the engine is not working properly. It sounds like a diesel engine and the alarm is on.
I went to the shop to see the error and it says misfire on cylinder 1. I changed the spark plugs (BERU), cleaned the injectors, changed the oil, oil filter, air filter, but no improvement.
To be known that this noisy behavior is only as long as the error is on (and the error appears only when engine is running on lpg), once I erased the error the engine is running well but with 1 liter more for 100km.
I talked to a mechanic from Mercedes and he said that if i could do something to trick the lambda sensor, which detects a lower O2 value, when running on lpg.
So, please, did anybody have any advice? Is quite frustrating to see that i paid 1000 euro for the lpg kit and I cannot use.
Thank you.
COPAEG is offline
    engine problems... Ryan27 R/C107 SL/SLC Class 14 07-05-2007 02:47 AM
    Engine Problems AxelWulff R170 SLK-Class 0 10-01-2006 06:21 PM
    Engine problems 89Benzo W124 E,CE,D,TD Class 7 07-29-2005 01:05 PM
    Strange Engine Sound - The Start of Engine Problems??? SLKDUDE R170 SLK-Class 3 04-28-2001 10:38 AM
    I think that my engine have some problems. Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 0 04-19-2001 12:10 AM
