Driving in snow - Mercedes-Benz Forum
post #1 of 66 (permalink) Old 12-04-2008, 08:35 AM Thread Starter
Minder's Avatar
Date registered: Sep 2008
Driving in snow
I have a W203 270 cdi auto saloon......Is it just mine or are all rear wheel drive mercs useless in snow.
Even a slight incline poses major problems for me...Downhill is no better.
I turn of ESP off and select winter mode in the gearbox which has marginal improvement.. It is impossible to fit snow chains as main roads are clear..
Any advice or comments wold be much appreciated..
Thanks,,
Mark
Minder is offline
post #2 of 66 (permalink) Old 12-04-2008, 09:21 AM
Kajtek1's Avatar
Quoted: 1198 Post(s)
good tires
Kajtek1 is offline
post #3 of 66 (permalink) Old 12-04-2008, 09:49 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Without snow tires they pretty much are.
4Matic with snow tires will be the best possible.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #4 of 66 (permalink) Old 12-04-2008, 01:17 PM
Mackhack's Avatar
Date registered: Feb 2008
Vehicle: 2004 E320 & E55 AMG
Quoted: 4 Post(s)
I made my drivers license in snowy conditions during the winter months of Nov through March and while we had some days with heavy snow back then I learned to start accelerating in 2nd or 3rd gear out of the stand b/c then you have less torque and that was always the key to start driving.
Plus of course being extremely careful while slowing down and going around curves. I found better slow down while stepping off the gas pedal way before you have to come to a stop is better than using the breaks. If you have to use both breaks and motor break technique to avoid sliding and uncontrolled spins.
Besides that, keep in mind that temperatures of +7 Celsius and lower reduce your friction a lot. Therefore, winter tires which have a softer rubber mix are always a must in lower temp. areas. Last but not least, the kat said it already, good tires are always a good and must have.
Mackhack
[x] Limo Dark Window Tint
[x] Bluetooth Puck
[x] Euro COMAND/DVD Navigation (527)
[x] UPsolut ECU Tuning
[x] iPod Integ. Kit (057)
[x] Power Folding Mirrors (500)
[x] THERMOTRONIC (581)
[x] Linguatronic (396)
[x] Interior Motion Sensor (882)
[x] 12V Aux Socket in Trunk (Y763)
[x] Distronic (219)
[x] Digital/Analog TV Tuner (863)
[x] Power Trunk Closer (881)
[x] Ill. Door Sills
www.mbretrofits.com
Mackhack is offline
post #5 of 66 (permalink) Old 12-04-2008, 01:25 PM
Jayhawk's Avatar
Date registered: Aug 2005
Vehicle: S500/W220/2000
My car goes anywhere in the snow. I have Michelin X-Ice tires on my 16" OEM wheels and have no trouble. Bridgestone's Blizzak tires are also excellent.
Don't believe everything you think
Jayhawk is offline
post #6 of 66 (permalink) Old 12-04-2008, 01:33 PM
The SL Hammer
Guest
Posts: n/a
Quoted: Post(s)
I have no issues with winter or at least allseason tires installed.
post #7 of 66 (permalink) Old 12-04-2008, 01:46 PM
Jayhawk's Avatar
It has been my experience that all season tires are not good in any season. For best results get the best tire for each season--winter and summer.
Jayhawk is offline
post #8 of 66 (permalink) Old 12-04-2008, 02:08 PM
mbkomfort's Avatar
Date registered: Jan 2008
Vehicle: -88 250D, -93 280TE-24 Sportline and -00 E270T CDI
You'll need to install some winter tires :-)
In this country the incurance company won't cover any damages/injuries if driving a car without winter tires in ice/snow conditions..??
mbkomfort is offline
post #9 of 66 (permalink) Old 12-04-2008, 02:33 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
The slk has snow tires. I would not go through winter without them. I still have all seasons on the ML. That one seems to do fine without the snow tires.
Mike
Michael Pillay is offline
post #10 of 66 (permalink) Old 12-04-2008, 02:36 PM
Mackhack's Avatar
Quoted: 4 Post(s)
I like it. Why should they if you can do some pre-avoiding measurements to not getting involved into an accident that could harming you and even others/innocents.
Mackhack
[x] Bluetooth Puck
[x] Distronic (219)
[x] Ill. Door Sills
www.mbretrofits.com
Mackhack is offline
    Driving in SNOW juntao C208/A208 CLK-Class 11 10-12-2005 04:53 PM
    Driving in snow DaveMHogan W163 M-Class 15 01-20-2005 08:02 PM
    Snow Driving NewBuyer G-Class 11 02-19-2004 06:21 PM
    snow driving gnosis W202 C36 AMG, C43 AMG 2 01-31-2004 06:07 PM
    Driving in the Snow demonio C209/A209 CLK-Class 0 07-09-2003 05:01 PM
