420 SEL fuel problem PLS HELP! - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-02-2008, 03:05 PM Thread Starter
Date registered: Dec 2008
Unhappy 420 SEL fuel problem PLS HELP!
Hi there looking for help with my Merc 420 SEL. The car had sat for around 6 months without being turned over, when I tried to start the car the engine turned over fine and all the plugs where sparking correctly but I noticed there was no fuel getting to the engine. Turned out the pumps where knackered, after having the pumps replaced the car ran like a dream, had been starting it bout twice a week with no problems until I went tried to start it the other day there. The car turned over as normal but just as it kicked to life it dies again, almost as if it not getting any fuel. I stripped down air filter housing to get access to the injectors, removed a screw in plug at the side of the injector ( As shown in photo) and fuel came out under pressure, when I turned the key to bring the ignition lights on, the pumps ran and fuel pours out the hole where I removed the plug. When I start the car with the with the plug out it runs fine, only problem is there is fuel pouring out of the hole, as soon as I tighten the plug again the engine just cuts off. Cant figure it out at all, thought it was maybe air but really not to sure. Any help appreciated thanks Gary McD
mcd240 is offline
    Picture Fuel Pump Relay 420 SEL guarddog W126 S,SE,SEC,SEL,SD,SDL Class 3 09-01-2007 07:25 PM
    420 sel Hesitation Problem MrFJJ01 General Mercedes-Benz 3 03-14-2006 08:44 AM
    420 SEL Fuel pump / filters question Big D W126 S,SE,SEC,SEL,SD,SDL Class 2 05-12-2004 07:54 AM
    420 SEL Audio Problem Guest (MBNZ) Audio & Telematics Forum 0 01-03-2002 05:06 AM
    420 SEL fuel consumption. Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 11-25-2001 03:49 PM
