Alignment E320 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-01-2008, 02:45 PM Thread Starter
IFS
IFS's Avatar
Date registered: May 2008
Vehicle: 00 E320 4MATIC
Alignment E320
After replacing left and right CV boots, do I have to follow it with wheels alignment?
The reason I am asking is that I have noticed after the boots replacement right wheel, outside, wears more then inside, and the same on left wheel, except that is less noticeable.
Thanks for advice-opinion.
IFS is offline
post #2 of 4 (permalink) Old 12-01-2008, 06:19 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't know if your CV boot replacement job is to blame, but if your tires are wearing unevenly in the manner you described, that is one of the cardinal signs that you need a front wheel alignment.
Musikmann is offline
post #3 of 4 (permalink) Old 12-01-2008, 07:40 PM Thread Starter
IFS
IFS's Avatar
It is the sign I need to do wheel alignment, but I did not have issue with it before CV boots replacement.
Just want to do survay about it before I go back to shop where the CV boots were replaced instead of go to MB shop for alignment.
IFS is offline
post #4 of 4 (permalink) Old 12-02-2008, 10:05 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I have read that certain M-Bs are tricky to align properly so just be sure whoever does the job knows what they are doing. Good Luck!
    1997 E320 alignment specs? Don Reid W210 E-Class 3 08-04-2007 12:26 PM
    how soon should i get an alignment? westonian W124 E,CE,D,TD Class 4 05-20-2007 11:33 AM
    Q)alignment? gang1126 C209/A209 CLK-Class 0 09-23-2006 08:30 AM
    Once again -- Alignment! Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 12 02-25-2005 03:47 PM
    Need HELP with alignment parameters question: getting alignment redone tomorrow. Dan - SF Bay Area R170 SLK-Class 13 01-10-2002 10:34 AM
