[W220] Auotmatic transmission oil - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 11-30-2008, 09:33 AM Thread Starter
Date registered: Nov 2008
Vehicle: W220 S320 Benzin, 2000 year, Silver
Hi all,
I'm new here - my name is Rob and I'm from Poland My car has got now 190 000 km so I got the following question - I will be probably changing the oil in my automatic transmission so here is the question - what kind of oil will be suitable for my transmission which symbol is: 722618 01 698446 (decoded form VIN number)?
I will be grtafeull for any help on that subject
Regards, Robert
Zgon is offline
post #2 of 14 (permalink) Old 11-30-2008, 10:17 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Use only OEM Mercedes fluid. Be advised, however, that routine transmission fluid changes are not required on these cars. Transmission is "sealed" and should only be messed with if there is a problem.
flyboyike is offline
post #3 of 14 (permalink) Old 11-30-2008, 10:31 AM Thread Starter
Hi
Thanks for the quick reply - that's what I've found on some other sites as well- that changing of oil in those tarnsmissions shouldn't be done unless something is wrong with it. Thanks a lot
Zgon is offline
post #4 of 14 (permalink) Old 11-30-2008, 11:12 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Didn't MB change this, at least one oil change was introduced, cannot remember the mileage. Tranny oil change would not be needed often but I would follow the period as for the first change according to the new service rules.
Diesel Benz is offline
post #5 of 14 (permalink) Old 11-30-2008, 11:22 AM Thread Starter
so what are the "new service rules"?
Zgon is offline
post #6 of 14 (permalink) Old 12-01-2008, 04:18 PM Thread Starter
and also can anybody tell me what oil I should use then? I know that I should use the oil that meets MB's approval 236.10 or 236.12. But what producent?
Zgon is offline
post #7 of 14 (permalink) Old 12-01-2008, 04:52 PM
flyboyike's Avatar
Quoted: 69 Post(s)
Use genuine Mercedes fluid, part #001989210310.
post #8 of 14 (permalink) Old 12-01-2008, 05:09 PM Thread Starter
Fuchs TITAN ATF 3353 Automatic Transmission Fluid will do?
Zgon is offline
post #9 of 14 (permalink) Old 12-01-2008, 05:10 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
You will find enough here about transmission fluid change, to keep you busy reading till Swieta Bozego Narodzenia.
czesc Robert
Kajtek1 is online now
post #10 of 14 (permalink) Old 12-01-2008, 05:26 PM Thread Starter
iooooooo witam krajana wiec tutaj tez zdarzaja sie Polacy na forum. Jak milo Pozdrawiam
Zgon is offline
    Ok, the W220 forums are dead, Hope the W163 crowd can help, I need exhaust tips for my W220 Man-Du-Ru-Gas W163 M-Class 10 09-18-2009 11:16 AM
    2001 S600 w220.178 Oil coming out of the engine wiring harness at the control module box. k.bop W220 S-Class 17 06-02-2009 10:43 AM
    Transmission Oil ojrana W202 C-Class 2 10-16-2007 06:06 PM
    Flushed Transmission oil & Differential oil (rear & front) today at the dealer wannaln W163 M-Class 2 01-27-2007 05:40 AM
    Transmission oil change with oil pump sam 100 W202 C-Class 8 12-14-2006 05:16 PM
