My 1993 190 is leaking oil into the coolant. Any suggestions? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-24-2008, 03:22 PM Thread Starter
Date registered: Nov 2008
Vehicle: 1993 Mercedes Benz 190
Hi, Everybody, I'm new to this forum. I just recently Purchased a 1993 190E, 4 cylinder. It looks great inside and out, there's about 107K on it. The oil dip stick looks clean, but when I looked into the Coolant resivoire there is an awful looking mess that looks like a carmel milkshake. It's thick and greasy. It's coming out of the overflow hose that runs from the resivore. I took it to a local mechanic, he flushed out the radiator real well but it's gunking up again. The car runs smooth and hasn't overheated. Have any of you experienced this? Do you have any suggestions? I would truly appreciate any help.
Thanks very much in advance,
Patty
howardscues is offline
post #2 of 8 (permalink) Old 11-24-2008, 03:32 PM
Musikmann's Avatar
Quoted: 6 Post(s)
That sounds odd. Did that mechanic replace what you had with MB coolant, using the correct ratio with distilled water? BTW, Zerex G05 is also compatible with a lot of MB systems.
Musikmann is offline
post #3 of 8 (permalink) Old 11-24-2008, 04:30 PM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Unless you're terribly unlucky, you have a blown headgasket. The gasket failure is allowing the pressurized oil from the cylinder bores which is pressurized, to mix into the cooling jackets of the block which are under less pressure.
Change the gasket, flush the coolant and oil, you'll be good for the next 100K miles.
Oh, if you are terribly unlucky, the cause will be a warped aluminum head, possibly due to the previous owner overheating the engine, but that's extremely rare compared to gasket failure.
MTI is offline
post #4 of 8 (permalink) Old 11-25-2008, 08:54 AM Thread Starter
Bad head gasket
Thanks so much for your response, from other things I've read regarding the oil in the coolant, this makes the most sense. I'm taking it to the mechanic today and having him change the gasket and flush the cooling system and oil.
Thanks again,
Patty
post #5 of 8 (permalink) Old 11-25-2008, 12:12 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
I think I'd take it to another mechanic, and it would seem mechanicing 101 to be able to diagnose this as a headgasket. You're due a refund on the worthless service yours provided earlier.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #6 of 8 (permalink) Old 11-25-2008, 03:27 PM
Date registered: Oct 2008
Vehicle: 2008 C350 and a Lightning.
+1 and get ready for some sticker shock when he (the new mechanic) tells you how much that HG is going to run you.
2tonOfun is offline
post #7 of 8 (permalink) Old 11-25-2008, 03:40 PM
MTI
MTI's Avatar
The M102 four headgasket isn't as big a job as it is on the M103 six since the radiator can remain in place. It can also be done without removing the intake manifold, but typically the exhaust manifold has to come off.
MTI is offline
post #8 of 8 (permalink) Old 11-25-2008, 04:58 PM
stox's Avatar
Date registered: Dec 2004
Vehicle: 1996 C36, 1995 S500 Coupe, 1985 190E 2.3
Send a message via Yahoo to stox
If you do get the headgasket done, have the valve seals checked. They tend to be pretty worn by 100K.
stox is offline
coolant leaking..shows NO signs of leaking on hoses cangolden W124 E,CE,D,TD Class 10 06-16-2010 08:40 AM
Leaking Coolant dahappybanana W124 E,CE,D,TD Class 0 10-23-2005 08:15 PM
Leaking coolant vanaaken W202 C36 AMG, C43 AMG 0 02-07-2005 02:57 PM
Leaking Coolant jdanish W163 M-Class 7 04-10-2004 06:53 PM
leaking coolant Guest (MBNZ) W201 190-Class 4 12-13-2001 03:47 PM
