W209 front wheel vibrations when braking - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 11-28-2008, 08:56 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 394 Post(s)
gabidospi.
I think that you can do some initial investigations yourself here.
Why not jack up the front right-hand side of the car, with the wheels turned to full left lock, and spin the RH wheel, checking for any problems. Then remove the wheel, and carefully examine the rotors, checking for signs of pitting (deep corrosion) on the surface. A slight touching of the pads on the rotor is OK, but nothing severe, which could indicate warping of the rotor.
Check also that your tire has not been rubbing against anything on full lock.
I also use a screwdriver to clean off the rust that always accumulates at the top edge of my rotors - the small area that is only just clear of the brake pads. This is often responsible for brake squealing and other strange noises.
If that side is OK, take a look at the left-hand front wheel.
bon chance....
keyhole is online now
post #12 of 12 (permalink) Old 11-29-2008, 06:37 AM
joedrt99's Avatar
Date registered: Nov 2008
Vehicle: 2003 c230 kompressor
Originally Posted by gabidospi View Post
Thank you for yours answers. I will verify the rotors. I'll keeping you informed on the situation.
Actually I think that I've made a mistake when I explained you my problem (because of my poor english). My problem is not when braking but when I turn to the left in short (example - when I go out of my parking).
also if your tire pressure was low at some time, the tread could have wore uneven.
joedrt99 is offline
    Noise and vibrations when braking samosali W140 S-Class 8 02-27-2008 07:09 PM
    Clunk/pop/noise from front wheel when braking smallfence W123 E,CE,D,CD,TD,TE Class 14 12-18-2007 04:09 AM
    Vibrations between 50-80 km/h on engine braking festerpig W124 E,CE,D,TD Class 1 02-28-2007 06:23 AM
    SL55 front wheel lock up durring aggressive braking s55sl55driver General Mercedes-Benz 1 12-12-2005 06:40 PM
    Vibrations when braking mmolina G-Class 4 08-21-2002 04:10 PM
