2000 ml320 rough idle dealer wants to charge $1100 - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 01-12-2009, 09:51 PM Thread Starter
Date registered: Nov 2008
Vehicle: 2000 ML320, '03 C230KS
Ok so here's a update. I have just dealt with the rough idle for awhile and have not replaced the wire since the misfire resolved once the plugs were replaced. However I did take it back to Mercedes, they wanted to check the EGR tub and valve. The said it was clear???? Now not only is the rough idle more rough than when I took it. When I accelerate occasional it acts like it is going to stall out and bogs down with like its choking. I let off the gas then try again and usually it chugs a little and gets going back to normal performance. What could they have done while checking the EGR that would cause this. It also seems to shift rough only in 1st and 2nd gear especially when cold. But did not do this until I got it back from the dealer about the EGR. Any more suggestions??? Thanks
luvinlife is offline
post #12 of 13 (permalink) Old 01-12-2009, 10:04 PM
nlehre's Avatar
Date registered: Feb 2008
Vehicle: 2005 SL500, 2007 E550
When I take my Mercedes to the dealer for a problem I'm having, they give me a diagnosis of the problem and explain what they are going to fix. Did you ever get a clear diagnosis from your service advisor? If so, what was it? If you didn't get a definitive description of what is wrong, then I would be careful about what I let them do. I would at least have an understanding that if their proposed fix didn't solve the problem, you would be off the hook for the cost.
San Francisco Bay Area
2007 E550, P1, Sport
1996 SL320, ASR, Heated Seats, Xenons, CD Changer,
My Cars: http://www.benzworld.org/gallery/sho...&ppuser=133412
nlehre is offline
post #13 of 13 (permalink) Old 08-04-2009, 10:05 AM
Date registered: Aug 2008
Vehicle: 1999 E320
I had the same issue with rough idle, my hood was shaking it was so bad, It turned out to be engine mounts, I replaced both left and right mounts and the car idles so smooth I can hardly tell it's running.
fastedy1 is offline
    2000 ml320 rough idle dealer wants to charge $1100 luvinlife W163 M-Class 7 11-23-2008 08:32 AM
    What should a shop charge (non dealer) to install rear suspension on an ML320? HACK THT W163 M-Class 8 07-31-2008 11:01 PM
    200 ml320 rough idle dis614 W163 M-Class 5 06-22-2007 02:47 PM
    2001 ML320 rough idle cea W163 M-Class 1 03-04-2007 11:23 PM
    Rough Idle Dealer Is ''clueless'' Thierry2000clk C208/A208 CLK-Class 9 08-30-2006 09:56 AM
